Walnut blasting a.k.a Dreaded Cylinder Head Blues
silverstreak18
129
67
Charlotte, NC
2016 M3
In hindsight I had not considered a more powerful blasting system. That makes sense. Just curious, do yours come out more/same/less clean than the photos I show above? I'm sure in less the time and elbow grease, too!
Those look perfect to me. A lot of times there will be a little bit of discoloration where the vacuum adapter mounts in the port since the walnut shells can't hit there.
derekgates
740
375
NW FL
derekgates.us
2011 335is
Derek, plugging the head is simple. 10/32 tap (use lube - any grease will work), and install the plugs with loc-tite. You may need to back the tap out to clean it after going in about half way. Keep in mind the plug screw goes in at an angle so you want it deep enough that it does not sit proud of the head surface. Also remember, the tap's tip does not cut full threads (it's not a bottom tap); make sure you cut threads deep enough to set the screw plugs below surface. It's a good thing to capture the aluminum bits. We folded some shop towels and coated them with white lube to help catch them bits: one towel to catch dry bits during the tap procedure, then a second towel we pushed in the hole when we blew the hole out with brake cleaner. For the second towel that gets wet, it catches lots of bits.
View attachment 17988 View attachment 17990View attachment 17991View attachment 17992
Fantastic reply, thank you. I need to pull the cover and get this finished. Will pick up a tap and try to find those plugs or buy more. Rob@RB told me over email a long time ago how to obtain more but I have misplaced that email.
