Rob@RBTurbo
Is this a 1.5” merge into 2” then a taper up to 2.5”? If correct this is likely a worse flowing merge than oem. Why not just a 1.5” merge directly into 2.5”?
Feedback thus far on fitment has been very positive!
Greetings from China. Mine just went in as well. We decided to wrap the silicone part as seen below. Might have been overkill, but why not.
More on my build here
Why would even think this is a concern?
Once upon a time I had VTT silicone outlets for stock turbos. Fitment was atrocious and the coolant tank had to be tilted a good 15 degrees or so for the hose out the bottom to clear the bend from the front turbo.
I'm guessing that you didn't read the instructions that came packaged with the outlet.... the solution of course being to trim as described, or at least contact us for some assistance. Regardless this is one of the reasons we went in the aluminum direction. The silicone works great when installed correctly, but install it wrong and you can expect poor fitment and for it not to last long at all.
very nice piece, waiting for some dyno results.
Interested in more info on the merge, PSP welds look way better than these as well.
This^ (and the PSP merger looks amazing as well FYI)
Really is a bummer as it does appear to be a nice affordable piece that should have great longevity (being mostly aluminum), but it is designed and worse yet put into production with a glaring performance defect. All said we'd send this piece back to China with the note of not having a post merger ID reduction and instead with two 1.5" ID pipes directly merging into a single 2.5" pipe.
IMO the biggest drawback in the OEM outlet (non-RHD models) is the merger area could be improved upon, however this unit 100% appears to be taking a turn for the worse as it is pictured today. The secondary OEM outlet issue is that the pre-merger ID's are a tad bit small for producing really big power, and this product has that improvement covered- but the merger needs immediate redesign.
Rob
Thanks for the clarification. I didn't install these myself.
I had a lot of issues with the shop that installed these, one more item filed under "stuff they did wrong".
Robert,
I do hope your Monday isn't ruined being as you're so bummed out about the glaring defects in our products. Yes they definitely flow worse than stock. Just like the silicone inlets. Just like the GC housings are the same AR as the stock housings...
Just like your China Ebay turbos are 40% more flow through the turbofold!
Anyway not worried about anything, just calling out the future for your product. Anyone with even an inkling of performance knowledge would understand that this design is absolutely horrendous, to discard such a thing really is telling of your credibility. But hey, a sale is a sale?
At any rate can see the headline now:
"2019 3rd quarter Product Update: VTT Outlet 2.0's now being offered pre-sales open with an ideal High Flow Merger" (that actually is an improvement over OEM and what RB mentioned a year ago)
OR you can take some advice and just get it revised now, could be a very cool budget option that provides some great performance attributes if you do not overlook the basics.
Rob
What are the basics anyway? Insulting the products/stating they don't work, then copying them in a year or so? Remember, silicone outlets were the worst solution... until you offered them. 19T compressor wheels were a waste of time.... until you released a 19T. Tony didn't make the hp he said he did... until Shiv came down and witnessed. Wastegate parts are "wear matched".... Stage 1 turbos are a waste of time...
I get it Rob. You'll be offering an aluminum outlet solution in the next few months, and this is a good opportunity to predicate your possible sales with some conjecture on a competitor's product. If nothing else you certainly are consistent.
