Volume of under seat sub enclosures
821
Not sure if anybody here gives a flying frog about car stereos, but thought I'd share this for the greater community.
Background:
I'm planning on sealing these up and running different speakers in this location as mid-bass (actual subs will go in the hatch). For my application, I needed to know the internal volume.
Method:
Results will vary depending how you seal them up - details how I measured volume are in the pictures. To measure volume, I bought a shit ton of 0.55" diameter marbles and a 1000mL graduated cylinder. I filled the enclosure up with marbles, then dumped them out and measured the volume of dumped out marbles with the graduated cylinder.
Results:
3.3 Liters
(filled to 1000mL 3 times + another 300mL)
Enjoy!!
Edit: adding some p/n's for general internet search-ability. BMW X1, 3-series, 1-series, e84, e90, e82, 65139143144-01, 65139143143-01
821
I'll be running the underseat mid bass with 2 channels from a JL HD600/4 amp (4 x 150 watts). I got some Morel TiCW-634ND to run down there😃 I'll be using a Mobridge DA-G2 PRO MOST25 for interfacing the amps to the head unit
How far along are your system plans? Do you have any components selected yet?
Reactions: 2aesthetic4me
pbondar
512
281
Looking forward to the write up…I went with Audiotec Fischer Match 1k with their MOST bridge …I suspect the underfloor subwoofer volume on your car is about the same as the subwoofer mounted on the rear bulkhead on E89s..
2aesthetic4me
Öhringen Germany
BMW E92 335i 2006
I literally didn't do anything since coming up with the idea 😅. My turbos just broke and while changing them I also upgraded the in and Outlets and intercooler and what not, so I hadn't had any chance nor money to start this project. I hope to get to the subwoofer project around Christmas time next year
SlowE93
1,766
Just a plane ticket away !
E93
Background:
Method:
Results:
3.3 Liters
Enjoy!!
That is awfully small 😬
821
Yeah😕 I modeled my driver up in WinISD; was hoping for a -3dB point of 80Hz or less for mid-bass. Sealed shows just over 100Hz, and free-air is even worse. I can get below 90Hz if I port and tune to 70Hz. But the port would have to be external, and would be extremely difficult if not impossible to fit under there. I'm still TBD which path I'll take.
SlowE93
1,766
E93
Nice, those things are beasts. Any pics? I'll just have two JL 8W7's this time around.
I don't think so. I switched things around so many times. I have pics of a custom box I built between the 2 rear seats. E93 does not have walk thru like e92s to get in the trunk. You can't physically get into the trunk from the inside of a E93.
I do have video of 4 10s I squeezed into the trunk of a E46 convertible 😂.
I should have took pics and videos of all my cars from the past. Some of those cars were hard to breathe in with radio at full volume.
