I know he has like the ring leader of bastard n54s. I think her single handed pulled down cr reliability rating 1 point lmao . Seriously though I feel your pain every time I touch sonething everything around it breaks.Ugh. How frustrating. At least you now have new bearings, brakes and rotors, the latter giving rise to lower unsprung weight and hence better handling.
But you had the problem coasting. So that tells me nothing in the driveline is the issue, except bearings (which you just took out of the equation. Diff and axles should show differences in behavior - under load, coast, back load. My 02 cents.
Just read the thread again and caught this - sorry for semi-hijack. Is there an Mfactory post somewhere on this?MFactory had a recall on diff bolts inside the lsd
I was asking for my diffI don't think this is related to the recall. I bought this unit after all their recall and they fixed it. The recall was a year earlier than when I got mine.
I was asking for my diff![]()
Here's another one we might have missed. Bad tire.
My money still on center support bearing
It happens in nuetral but did you every try applying e brake while in nuetral to let the load reverse by using inertial of driveline spinning?
Their was a set of bad bolts distributed years back that would back out do you know date of manufacture for your diff?I was asking for my diff![]()
