Vader Solutions BOV adaptor
cityazndan
108
14
2016 340i xDrive
Can somebody list me the hardware i need to install the adapter. I did not install my charge pipe and bov be cause i wasn't sure what i needed to to the manifold tap. Glad i found this adapter!!
Adapter comes with two longer screws to bolt your MAP sensor to. Use rubber vaccum caps to seal off vaccum barb coming off the IM. Use 1/8" NPT hose barb fitting to attach the adapter to your boost vaccum line off your BOV. Pictures have been posted of the setup complete.
cityazndan
108
14
2016 340i xDrive
It says...BOV adapter for a reason man...but I suppose you could. just be more plumbing involves and a Y Tee.
CTurtle
2009 135i
Sorry if I sound a bit slow, but the threaded end of the barb nipple thing screws into this unit?
CTurtle
2009 135i
Look at the pictures man! but yes.
Thank you. I’m not seeing which pictures anyone is referring to. On the page for the product itself it’s bit clear to me. I see no lines running anywhere. It’s clear because of your answer not any picture that I’ve been privvied to.
CAA
28
E92 335i ST
There's an advantage to run this bov adapter with thicker bov line (than oem line) for auto guys?
I'm having about 5psi boost spikes on my 6266 on upshifts. I changed my bov line from stock 4mm to 6mm, but keeping the stock little nipple at the manifold, there was no changes at all.
4,342
Your symptoms aside, increasing the hose diameter while leaving the nipple the same will do nothing. If anything it will make your bov even less responsive.
Reactions: Frenchie1013
BreakMyBillfold
81
34
Installed mine today, finally. I like it.
Traf
362
206
135i
I thought it was not recommended to share the sensors with anything ?
BreakMyBillfold
81
34
That sensor is just a pressure sensor so it's not adversely or noticeably affected by the spacer. The TMAP in the charge pipe measures both temperature and pressure and is relatively more critical. According to a post elsewhere by Terry from BMS, the MAP in the intake is only used under vacuum and the TMAP in the charge pipe is used under boost with the MAP in the manifold as a backup.
Make your own decision, but I think the minuscule increase in volume from the adapter has no appreciable effect on the ability of the sensor to measure vacuum/pressure. I have a port injection spacer which adds much more volume and I haven't heard anyone say it was a concern.
