That sucks but at least you know what to do. I ordered my camera on Nov 29th and sadly it looks like its barely entering the country:
Also, did you test the camera to make sure it engages when you go into reverse?
I tested the module by connecting a DVD player (lol) to it and shifting into reverse. It worked.
I got the new camera in Tuesday, and installed it last night. Oddly enough, the new camera had a longer cable, which meant I didn't have to fish the thick molded plastic circuit board thing through the flex tube, just the camera connector. Much easier this time around.
My module doesn't seem to be sending out 12v out of the white wire to be connected to the camera, so I just tapped into the red 12v line that goes into the module and that works fine. I'm not worried about it killing my battery, as I confirmed that the car shuts off power about 20 minutes after you take the key out.
Here's a pic of the screen:
You'll notice some distortion in the feed. I can only assume that that's the camera trying to compensate for the wide angle. Oh well.
Interesting. What do you mean by thick molded plastic circuit board?
Here is a photo of what I got. Does yours look like this:
Damn give the guy some credit tho..
You used most of his pics.
http://www.e90post.com/forums/showthread.php?t=1005301
Is there any kind of lag on turning on the camera when putting the car in reverse?
I've heard that these tend to do it a lot.
not really I ready that could happen when there are poor conections just make sure all the wires are nicely jointIs there any kind of lag on turning on the camera when putting the car in reverse?
