Twin Turbo Wagon: Evan's E61 Build Log
TwinTurboWagon
228
244
San Diego
Due to the type of damage the engine (oil pump) received it was unlikely the force could have been transferred to the crank so I focused on rebuilding the timing chains, cogs, guide, and pump.
I1XswoXk8fZpIbfVmJyFHalKqX5klkeSk_IaeEPwaiGEz07MvIW5-CBPKwWQVOhUYrOGiigD2VaeYusEYQ=w1318-h988-no.jpg
Clean and inspected turbos
ktbeuCQy2T04HLSMagNqZU_9-hrzH97k0bjw98jV9tYeSEx2PTCYF3tpEu2COjAu4FdD5TV6zrNgfgarHA=w1318-h988-no.jpg
Retrieving broken valve cover bolt
dXcWpfhDOow18KuspADz9XvnrceP_F1e0yygqXeXUOID1FiHBkCtu4wSbVVqnbJtqchst-3_0Ub_JBvUIg=w1318-h988-no.jpg
Fixed!
dkJcePHmGf1LNpIiTXA8L4cLoYlLZA1rIda6J16hyoIeOFSANeY7ff5Wx2LzPDKTND7IhWIucx0Nu7350A=w1318-h988-no.jpg
Valve cover removed and everything cleaned as much as I could, my index 12 injectors were installed
_myW-fvo2FIg1fHXNNdduiZfU15_p8z97hj-8p-wsSjkDwP-sw1naPMzqHEvK1GDyFXcvgR0DtfYlx7LVA=w1318-h988-no.jpg
Leak down test, strong numbers ...thank goodness
daSfpox_DMRhzoBhgnkPcfL_1DwFOIkMUSbzzrmK4UuQX-mEZ-7CAuAX7IIyYTY9YXU-iw0niRjSgI345w=w1318-h988-no.jpg
New parts for the "refresh"!
-GvE6JEr3KH1NkfnyrGk0jxO8-ruYyzmLkZnBj-X0RigoMsoGKnHiZefEJzk9V7SHeBaGFTYeK3HZ9Xsog=w1318-h988-no.jpg
Cleaning the valves
iilX7HdlGqroDAZIJ26QF18Z-M5iRi3rvGdibAzEpVv5gBmwmiveLkxtZ9cGKHBCBEwhbK2ddIlgZRP5hQ=w1318-h988-no.jpg
-4CsDuJeYlE9NNOStJgb_5r2a3Geid7spzOn4FLDlnSYkemkyReze7ntzw5uft0nAfztZMaAD5a7X4HgVuVJBdJA=s988-no.jpg
Purchased a 535i oil pan off eBay
6AM2mto2i5PObYOb6x9lCYp3EUUIUdLPm5zN2yUbwnShK3hTWsMoTAMmR5ud0G_BNGY5U3y-bWBzRnUBIg=w1318-h988-no.jpg
Transferring oil pump from old engine and replacing timing chains etc
H_yBt9ffukCehwc4WBp29JkAYtacPwLJVcDeKElQTLWUH_qHAT6lu-7OXhSqgi_TnDISfCBLGsTv08ZkaA=w1173-h988-no.jpg
Removing crank hub bolt
iDfclWcptFLNe_9nG39QQCitrkIscB2TfnQMEZMSoYwnBFVdktb-VR2tyZxpJJtggza2WJSRVM81gj7g5Q=w1318-h988-no.jpg
Vanos removed
q22iosY_FGHLFdMoOeiJUfKAuea_v23jSVSWaHORRR5rpNCCI__1RwV1i0Y4k8fnXWEoC3tWHIXRcyHLvw=w1318-h988-no.jpg
Weeeeee
Cj3ofErQm5yjGga8UyaR-P-C6H66AA6whf-ZJOolLc8nVMrhJrkZ7Lo0f_5qFObav_l9auTUArsaAxmOWQ=w1318-h988-no.jpg
Pump on
LwzqYVBye-oVykoZ_BSg-dDapKoTU6MBqp77hoO_swnMeBJLm32ZLOa67HsEYxPjziAtxfXZZRqkMVJQnA=w1318-h988-no.jpg
Setting vanos position
fzRh_nUaiUTbDXgvtJCSvylT-oJqV_D3q9X5AMRoumOfWM_U_f6jea653PLNm80T6hNi3_6gkUGQQ0LVQA=w1318-h988-no.jpg
Looking clean
JXTbYlO28zKZTvwtUV9TnNFMFG62jYKEPG-ZcrUGKNfp-aO71erLFn5y4zXSbnTj61DgjBWuIiSVE0KArQ=w1318-h988-no.jpg
Valve cover swapped over
F2NIBlECP58r9yIxf8h41qw810P-V2fsPYBqLAwUg4u2Ym2eUYvbERt82XtW2hZiXoIGzW1ikCGNOPoLTw=w1318-h988-no.jpg
Bags
xZOcCdMUoC_gKEP8LJbqiDSCVZ2NHqZrg163aOqgrAYQjGeMpWvAX8yaIsYGPdVESfelk38hbVVKVZcmgw=w1318-h988-no.jpg
Belt driven accessories and fuel system getting bolted on
k5gu7pPDrAszhAsQ3x0WSagnhbRSmGgblAnsx961nQVPZ-Wal6JvI3PpZtRKsHuNWAGLOYysm7coUCoslw=w1318-h988-no.jpg
TwinTurboWagon
228
244
San Diego
Carnage from the old block
j_m9eqUXLh9BBDwFxImLupp2h0_ieTYpjIP8s6_5wpJdt47JtRJMuFid9t97pentNbRzrC9xCfkOh0ejfg=w1318-h988-no.jpg
Easiest turbo install ever
poIgi5GVCSYxLz2vKiGjLUeW4JFRolxxK3mR5TJ4OwRWId2yVaGJlbuAnt62xqYYEo6E2e7Tf9-cDop7nA=w1318-h988-no.jpg
Mocked up the inlets, outlets, and downpipes
crxLf9XjWU98cBfhkkp3wrp7VkHISrz81QVFe-haCJFY5ISjaVSGvj11Neo99K_k3FnTU-nP1dKw_h7Y3g=w1318-h988-no.jpg
Cooling system on, engine ready to go in
FVckjJGAghASSE2v-3Jpx1sKumPayhzrTWGGleD_jb2jkDt8jF9Ur-gvk-fAhAV6nziTYytLoQ3vRA25JQ=w1318-h988-no.jpg
Tada
RN3Zx2PVQiuBtK2NmGwh54UJyRR32pKM4CoRHI83bTD-rpIao4PyzIj5QdrDwQlxAmvSpGmpWyFY6t4p9w=w1318-h988-no.jpg
*Snaps fingers* and just like that everything is back together.
HTGFVrJ_TVVPw6tdlrcZXm-D8wkLO9L7MmhC5LWR3y9tdDAx558AqvyVBO7755dsmwbQHlavT1WLkKquGA=w1318-h988-no.jpg
The parts and tools for the engine refresh cost me about $400 and I sold my old undamaged head for $500 on Ebay. There were probably some expenses unaccounted for but I consider the entire engine replacement a financial wash.
Reactions: rebo0t
4,345
Haha that piston/rod, that is crazy. So what are you going to do with the hoist and all those tools? :)
TwinTurboWagon
228
244
San Diego
Man I love this and your attention to detail
It was my first time in an engine so I opted to be slow and methodical versus quick and careless, the fear of mis torquing a bolt or forgetting about something small that could potentially lead to (another) catastrophic failure was motivation to stay thorough.
I am selling the hoist and engine stand for $180 picked up which is essentially 1/2 of what the regular price is at Harbor Freight. I have a good relationship with a shop in Costa Mesa and was able to borrow the vanos timing tool.
The leak down tester, crank hub wrench, and some other tools I have are sitting in my garage. Perhaps I can lend them out as a rental to those interested.
Evan
Reactions: rebo0t
4,345
Evan
Or maybe for when you do a full built motor? :)
TwinTurboWagon
228
244
San Diego
M5 Drivetrain Retrofit
I would have loved to keep the AWD system, it ALWAYS hooked up and having foul weather/ snow capability really was appealing to me but with my power levels and ride height I was having issue with the front axles and I know there was a lot of stress on the front diff and transfer case.
For the sake of simplicity and reliability I decided to convert to RWD, beefing up the drivetrain to M5 components was a logical upgrade, the M5 LSD would also help with the newly adopted traction issues.
Mechanically the retrofit was fairly straightforward but offered a couple hurdles to cross.
- Custom length driveshaft
- M5 MT output flange
- Trimming of LSD heat sink (E61 has large pull rods)
- Boring out rear LSD mount (since I used upgraded MFactory E9X mounts)
Keep in mind I already had M5 brakes and rear hubs so the axles were bolt-on for me, AFAIK they would bolt up to RWD wheel carriers but xi will need RWD/M5 hubs as the offset is much different.
Since I was going from AWD-RWD the ABS/DSC module needed to be addressed and proved to be a bit of work, this will be covered in another post.
The transmission flange had to be purchased new since anyone with an M5 trans wasn't willing to pull the flange. The other stinger was the driveshaft, I snagged a MT shaft off eBay for $175 but ended up paying $600 for the full rebuilt and lengthening, it is brand new and custom but by far the biggest expense of the conversion. I got the axles for $100/ea, LSD for a crazy good deal ($250). Axles, LSD, have ~50,000 on them. Driveshaft is "new." All new mounting hardware was ordered.
E60 M5s have the clutch-based Visco-Lok style LSD where there are 2 clutch packs on either side. The downside is there is more play so this type of LSD isn't great for drifters or the track due to the slower engagement; the upside is for straight line grip the clutch based system offers superior traction. The design is a bit flawed since the clutch packs are not serviceable so over time the slop gets worse, there can also be some grinding during full-lock turning, the only solution is some crazy expensive gear oil with a friction modifier (it costs $150 just for 1.5L of fluid to flush the 1.1L diff).
I am not a track star, I don't mind the slower engagement, and considering aftermarket LSDs are $1,000+ just for the diff itself I am happy to run the clutch setup. So far it has been working very well. My wagon is about 4,250 with me in it, I have 285/35 Hankook V12s out back and the tires hardly ever slip at 22psi and 1st limited to 18psi. The most annoying part of the LSD is slop which in combination with the toucy BMW throttle can lead to oscillation/jerking is given too much or too little throttle at low RPM. My old E39 M5 had the same issue and same style LSD.
Evan
Here is a peek inside the LSD
dItcJ49FvMRvQ66-ihpM7B0Mes-b-IYbeEu18YuM1RsFw2ApJn1nMMIhugPDr7KRuJ_fKlXyZEzot9b7tw=w1293-h988-no.jpg
M5 Goodies
lomBop6il_a5-yUqC--zJGpqRRHcY83RCeL0WSeLDBYfhiPhgmOJIqUPUXlNtkV_lZSm46ark23udHMEDA=w1318-h988-no.jpg
Axle comparison
xx_S0QsJJtteYMc5K3fFV3sSl0Nl6Tston6LURO2JNea5Lo2EE4x-vAb-ijMLJHyrxVleNdUoTEh-ItI98IIwAtw=s988-no.jpg
wpPeYdV-Um6FSYtIN3Fzu2qDYXtf15kErTnMZJ63w63kN2BFoKVP1kb3Ne9t7O_AXiCl8spy5N9I5uqTog=w1318-h988-no.jpg
EjoxJdaDEiMC7eG4HXprCSZAbjuAgepJGmeLUvi5udeGmWSoX720UWmNijw-f9wyzf9nhQZAyDNpaF069Y=w1318-h988-no.jpg
Driveshafts
UwwTIQh6OEIx3lywZEhFF05ZiZpyPmlaEIdhNjx5taRLfaHUrH_OzImMoSE5Bm1zopK_obfPxuqCm4Gj0E=w1318-h988-no.jpg
iZ8gjg8HMIioHkYMX6SzK5hKUQEHExrmF_WOpmftr_g3VCP4K1q766uA0KoL0REf1Ba3Q_apNxjRBPpfzY=w1318-h988-no.jpg
Trans Flange
Sk0MFq0bArLr4LHeSk89GP2aw7HoheVVE1CcjOqQeTVFhf6nLds5J-wnfcfgb-rWwusymGE1x3EyV4K6Iw=w1318-h988-no.jpg
v4S11GoFdr32IMS-S8rA2zknppipaaXANXMW8239_0sDBxyLs2-byxw0NbwV4IaKPiXrffaazimbsZ9MX0=w1318-h988-no.jpg
Oem Diff mounts vs MFactory
2mNjAZukthpH6WK1OQJPW4IPSeoiQfNYqu0IlJ94QsZdRQWi-eXdSfdZ1IPYZjCnNTFQ8YAtSlUjJCHDoK1ZNKOA=s988-no.jpg
Built a bushing press tool to remove the oem mounts and install the MFactory mounts which are solid rubber with a larger metal core.
FihWgsSiiqBNqKb0C619hZeZLNFSsxO4KDNAl_4BuoBjWOjxwCjEEjgg0l6j1-UaMYGyhzzIZUZBNPL7iM=w1318-h988-no.jpg
Test fitting diff
OXSZFN9Y2RW5zGZR8Mglt3CgxZWxhYJ9TnGNH6HtCvru6leFqAa0SqEOAeXJwVVEQ5UUhOrAC_zf6NsPcs=w1318-h988-no.jpg
Exhaust too close for comfort
Ctr-f6NhBfmdwwmySVSnXD-tXQ5ZNHvIPAWc6_i12onJQlV_F28Gf9r4Il5egsb79OUKQk9MKdlVJf_byY=w1318-h988-no.jpg
E61 Pull rods wouldn't clear the heat sink, there are different M5 specific pull rods but the non-M variants seem to be superior with better mounting points so I made them work, best of both worlds IMO.
HI5jHLMMEMr_K3PPtfyQBCBgZ9TIrXDJeRphUzmK_AmREzmzKYQ4HdUyU1hfuuHXv9DBGeOaahyM080kCc=w1318-h988-no.jpg
Sharpied the areas to trim, I told track the wagon so there are no thermal concerns with the smaller sink
yDWFxaiSNVwmYesl8PugUaxsdFqaSPp3SCzD70afOrFrOBRm6uZybGBZn7CHRZTgqruwug5bGFdItYLd2o=w1318-h988-no.jpg
Hacked up with an angle grinder
IDnYdSg4S8kp2uA-VbsWryaBPwLpvL5YFCIjlgIIng4cOvWwZ64KSio3JmeIq7br9hv8-vHbFuJpaqKw-Q=w1318-h988-no.jpg
cztizzYCARZQXeBQElb9CzwHGaL25jW-eZSBvVxpVoR0jTfZZjv8SYImNXiJJbTdWrvHh0hYRuWSjUeWUY=w1318-h988-no.jpg
Hit it with a sanding flap
XGPNMtm6Sa7wNHOgSUo2ceCj-G--mIEc6KCH81KORUtxjJexRRrsFThdvEMeAtk8E5vUBOebnp6sBhvCps=w1318-h988-no.jpg
Not pretty but "fine" since this will live life under the car
nBJSw3guMMVEe4tEfFwDGWJSFIIojPd9YstwbaR-MauUfH2EHRvKhPqxSNyGLkJRCSG-FQdH4_bcOQWIoA=w1318-h988-no.jpg
Non-M vs Stock M5 vs Trimmed M5
SNVyoQgTxhewkkMx1TrXYpEPpqrrXqVDZLW22OIUWZnE_wMqyATcx4Yumyqrh9dbVdKfpEyt36O8Q2i3j4_piU1s=s988-no.jpg
TwinTurboWagon
228
244
San Diego
M5 axles in non-M wheel carriers.... if it fits IT FITS!
gEKUyN-BeElxQQUKWM0CvyBku4MWvWQ4ZgaEJ9CiXkmvdZG4_tY4cuZvEvFdq0FzqKhLQXWuUzpN_JWpg8=w1318-h988-no.jpg
LSD and Axles installed
KrCaay_9FQsfrVPoJWfPImUdHN8F15Zku1HE5Q8Ck1070KPgVro8FTZuSRgRqvivndbow9X-FmgPl-lKso=w1400-h988-no.jpg
Pull rods clear
hKcZrwUxCqQNGFoPD-c3oSC_CFMV5mliuYFWJ-cyHE-VbDcAdEwVXE4VyjThtKpYxLvkwboDR13GMUagQQ=w1318-h988-no.jpg
S12rXHlrFtCfIMmzad8aBGY0gccltFk014UTenckt090Dl0z7jqP8E6q5wU4n_mhX4SBB_rxaV9XNmID8k=w1318-h988-no.jpg
My counter-hold while installing the M5 flange
qhN1PBBx8J4Nd8HUNtxZxKZ9qAc-pbn_YPZ-Wtt2Zg_3G8NATgTIcSxCbuBEsX4xfhXcxN9FTtlo9oYxGY=w1318-h988-no.jpg
Guibo is also M5 specific with a larger diameter
EpFgHAtdeC7yTfxTVeBdYGl09MpzEJXZJo4IZBLvLRKm6qn-8JNrR_HpyQZYImEBUpHUVUYmF_ke4bdrf0=w1318-h988-no.jpg
Measuring length for driveshaft, measure 5 times and pay $600 once
k8q5Zs-Vsl2LCHn0RXckpXSrUTtXARSsxTSFNHma7zGFH4wLTPggRrzXN4vnRLYw01Mrwd0lO7T086tfBE=w1318-h988-no.jpg
Lengthened/Rebuilt Shaft
P1PKJaUUKG4WBD6wlg_2qXvGSeiKaiC9KLH2NHoIRhNOQjoN2DMpMU000FjhhvlKj_Nq1K-_wRWa_XaTdY=w1168-h988-no.jpg
Weld
i2sVCcxchXsn3wflk-F4KldQUcbVCX4GnRHEykbikRoBGwibSVyyx9TTl5gsOTm_MLqhpskEqXRbh1ishw=w1318-h988-no.jpg
Driveshaft in!
z6PP25cBX1HoHoTs0NmtejjuhGG_A1bAYmaYpWhKjg4Nj0Gl9-hRzj05pTFwjm0WInWcnABfiyrcHYIuDk=w1318-h988-no.jpg
Braces and exhaust installed, it all fits!
a8VYvf3YzgUbERTl_rHQyiJK77wJlQksYaeGZgdgftWdTxVX-Z-VaUElrCH2icpr-Om-yBYbq2O8GUVR68=w1318-h988-no.jpg
TwinTurboWagon
228
244
San Diego
After resolving some previous DSC codes (thanks to Levan) I had another pop up after a short drive, presumably it was suppressed by the previous codes but this code was related to my clutch pedal signal was always being "on."
Long story short I had the clutch switch wire which runs to the DME in the correct pin location but on the wrong connector, my wiring was ALL wrong on this MT conversion. lol
qHpFOapzCGKwIdUe0OVSjDeJRiBp6-H52qYZCp5JPJ4jhblCCmVqaC3R2ak6Fnhh1UEWQ5m2Og_2H07uj8=w1318-h988-no.jpg
Clutch switch is the purple wire, pic below is the WRONG connector. Funny thing is pin #18 was perfectly unoccupied with the surrounding pins filled.
EVjL5lA1eaBNSpl4jcrDE-K-i7ekitplU96dM9WAq-ig0Ji9aoFT20v4nsfr0Z01dzJwg1bQTqfjsRGgho=w1318-h988-no.jpg
Here is the CORRECT pin #18 on the smaller grey connector.
9-9LxnXQoCyTPg_ygbcp9zbgLvEvjTKCAh3S2syC-wA31gjam2HG3d8XFV-PdoBsyyhyY8r8VfISqj9y8c=w1318-h988-no.jpg
With that small victory under my belt I turned to evaluating my upcoming shifter modification where I will take my UUC SSK, remove the adjustable aluminum sleeve, and have the lower steel half cut and then add M10x1.5 threads. This will make the shifter modular and I can swap shift rods as I need to fine tune the length.
The ORIGINAL plan was to build a Ferrari/Lambo inspired gated shifter but unfortunately after some research and deliberation I think the gated plate would probably create more issues that it's worth. As it is I still want to retain the stainless steel knob and rob look. My UUC is real direct and notchy so I think some added leverage and weight will compliment the function.
5zjALDteqCqpKBceSHvUy1Node4DC-LrAfYsPVnSmv6l5d_FbgLZ3hqd9dtsaXdqxW6LPHbmcWl5j7OonvE=w728-h485-no.jpg
The plan
Wqn-cHwEtln4avYtdCmMU28wwiWhpcD3UXvBdW9T1RRRw2Hx0uE99M9z5u6uokii7N_jX3pTUSLLTkvcKw=w1318-h988-no.jpg
Typical weekend...
rwdX2UJ3GVs6CQt6AF0GnVDhW2SxrzNsuQeEjdqz8KJ0xdWvm9TAeyQX6xyzFbRFQ4i7JLf0eB7kzehKPM=w1318-h988-no.jpg
UUC with aluminum sleeve removed
rot-L2Z_fCw-vkFOSIah0RN11NZuFxxLqFEf22UhkVDN-Jq6QXls1N1hYQqQAxJVLIN74q1WztkdGFoky8=w1318-h988-no.jpg
UUC dia
d7qw3sbPCFEgU3Nmsv1MemCGgj5D0AK6rIOnJngFqTjYkyKNPTFIlO6R2N2pvAr_Nhv9_LGuJ9LVqZL5LU=w1318-h988-no.jpg
Stainless steel rod dia
EWS-wj0tQBJEkWMTff8WyJj4r6o4PBXTdy7mujmIb7QY7YuBRWm9yzEqhphxA_wTujJ3KDjmmRXCvmAgT8=w1318-h988-no.jpg
Top inch will be cut off and then 1.5" of M10x1.5 cut into the shifter
im09PKyCCz6Al0AnRoP7Wh0ARTn_L_dfjdbtBQ6iqTUip7jHasNeI0a9jLfVoLJtE1rWGGh6Bc4OWwZPOI=w1318-h988-no.jpg
Something like this but shift knob will be ~2in shorter
8lcUzU372YeTkVjiVwLhCTA9Uz5N1Co2A5rwHOr2LgGM6s21FTzME5wbZsCY07TlIwuxBONJfuk2-FPLQQ=w1318-h988-no.jpg
Shift boot will be replaced with something more "awesome"
xeJkV3565PyLKDnajXh2Evp6waU0Nq42HUVOYJYRpqV84FyWdT5AJ42wJgMXXmEq3WWvTN0TDo5qBgrAWM=w1318-h988-no.jpg
4,345
So the shift 'knob' is getting female threads and the shifter linkage part is getting the top cut off and male threads put on, right? Any reason you don't just weld it on, is removal more difficult that way?
TwinTurboWagon
228
244
San Diego
The 6" rod attached to the knob already has internal M10x1.5 threads cut, you are correct with the rest of the process.
I am choosing to cut threads so the shifter will be modular and I can swap in other length rods if needed. Nice to have options.
Evan
TwinTurboWagon
228
244
San Diego
When pulling my shifter I noticed the PVC insert I made to firm up the shifter arm bushing had slid forward and out of position.
ndMn8ajhoB-NiFxypHMGCB2Ck_lyaYVWzpN8_m9JmB0Wtx_K-3NrF4VicOyY6eXnmBZ4Uk6MPuT6WbCZF8=w1318-h988-no.jpg
I secured it in position with some wire.
8WBMxWfL3OLQsNsQM-q4EPkH0obdMYy3X0vfkuS3OYcgQv06dQDUtt3i6Gem5Je5IVmv_1VppmlAMV6O7M=w1318-h988-no.jpg
Shifter modified to accept threaded rods.
cS_PFjSjIvj0KU8FjJmUDBT4GoJ9M1IIEERc9X9-7SL_p9uaMFGZy5KUmn2me7DJpQ6dj4bc9IjkNhY_9PIQfZnU=s988-no.jpg
Installed
7y6DX3_UqBapI8c8YwN-ci_KsRtnPumTSAJUvarKSdNNG6Q7hu2LUE3sonnpM7BsSYiw7A7kvSr5vos3ro=w1318-h988-no.jpg
The shift rod and knob are solid stainless steel and quite heavy to the added weight and leverage really smooth things out which is a welcomed addition to the UUC's already very notchy and very direct movement. The shifter is a tad "floppy" with all that weight up top but this is only noticed when checking the shifter isn't in gear and other light movements, while driving when the shifter is used with intent it feels great. There is also a sense of occasion when using it from the looks, surface, shape, etc. Just what I was going for.
Up next is a custom boot to replace the overly saggy oem leather piece.
Evan
R3sZa3QB-OtVw_CfcBHZk6DKPLbudgbdtRT5a_uvveSJeSFnPR8oxZuG4sHI59S1nZtfpLPmexCnoRdeoc=w1318-h988-no.jpg
TwinTurboWagon
228
244
San Diego
Are you going to have a custom boot made?
Yes, haven't decided on the fabric yet but thinking of a plaid, something similar to the GTI boot but with tan instead of red. Which ever fabric it is I want it to be tidy with enough room for full range of motion but no excessive fabric.
Audi does a good job with "tidy" boots on their electronic gear selectors.
TwinTurboWagon
228
244
San Diego
Install Error: Noticed the silicone elbow on my IC getting rubbed by a mounting tab on the subframe. There wasn't a hole but silicone was compromised so it was replaced. If it continues with engine movement the tab will be removed, I didn't like it anyway.
19pAbSFnLCG4mleUxnXZWUV2Oic4xi0bFR_GLegg16mnQ0A-DhWdz8uoIMv91RcdYoX19PX9CUk-2Nw5Fg=w1318-h988-no.jpg
aRn6GsMezeZuCeZwl_OK28kbvQRWidmyw2hEDfjBpZ1dZadqh6dap4OpjY4SspFaNhEzSFh0imnRJd8LOg=w1318-h988-no.jpg
With my new slightly taller shifter setup I would smack my phone from time to time while rowing gears so I came up with a different solution. Not ideal as it is now lower but I mainly use the app for checking temps and datalogging so no real concerns. It does clean up the center stack a bit which is nice and access to HVAC is unobstructed but most importantly, room to shift.
SYOynQjtJ0u837Lnn1ajQ0y0S7PVokD0HJunft6U_C9E82TLU-XyQdSnh5ykBkYKiMiMsdJW8ar3hmTiEw=w1318-h988-no.jpg
tYFXk30zGi9hn5XjadU-XAD7Qm7FafHCi1sldUSWKf9xg601ox7SvqPfwus5D8eNDBB2GKJXQHUupwuaqw=w1318-h988-no.jpg
VGlSC8eSSt4eH4uZiMgg-6YgCBeWh7K-rRNz39VxXFv2-aDO24JcsRPDx_i_bYSeWZitVhge_5jfe3qRzQ=w1318-h988-no.jpg
4,345
What tab is that exactly? Luckily the ADE FMIC has an aluminum up pipe there so I shouldn't have to worry about it.
TwinTurboWagon
228
244
San Diego
Not sure exactly but my guess is a mounting point for some of the oem under carriage splash guard, which I am not running since I have M5 bumpers and 535xi subframe and engine and BMW doesn't make parts which connect the two. Hoping most of it will bolt up once I get the RWD subframe.
