TTFS/XDI late e-series single HPFP upgrade
Xer0449
174
59
We will see :). I've asked Ken for an e50 map <= 19psi with some timing. Let's see if the issue is reproduced.
4,348
19 psi usiall it takes to get the dct flywheel misfires? Either way you're six bolt so you can buy the s55 flywheel or the mfactory flywheel. Mine actually showed up in the mail today.
Reactions: Xer0449
Xer0449
174
59
I think the magic number is either 21/22 psi. Is the 1100$ flywheel + time/labor of dropping the DCT worth it for a few extra psi? For my daily; probably not...
NoQuarter
1,662
1,067
Indiana, USA
Z4 35is, 535xi, X5 35i
I think the mfactory was much cheaper than that but may not matter anyway. They don't have any more and have not stated they intend to make more (yet).
Xer0449
174
59
Yeah, looks like I was too little too late on that one. Such is life.
houtan
657
336
135i N55 DCT; PS2
Looks like the car is running solid Anything above 19 psi and it’s hit or miss for my car.
The m factory flywheel is a lower priced option if it performs the same as the M4 flywheel. We should know soon, hoping it works as expected and if it does, that m factory makes more!
Reactions: Xer0449
Xer0449
174
59
Are you running the stock DCT fw? If so, what kind of timing/fuel are you running?
KevinC39
234
118
wow that is expensive HPFP. how come you don't run pure E85 WITHOUT MIXING?
There's no reason to run more E85 than you need to. Running more just makes the pump work harder and makes you run out of fuel flow sooner
houtan
657
336
135i N55 DCT; PS2
The main thing I can think of is, running straight e85 is much more convenient than having to always calculate your ratios every time you fill up.
KevinC39
234
118
True. I was just explaining why you wouldn't want to. Convenience is definitely a reason to run it straight.
Reactions: houtan
4,348
Unless you get E54 from the pump like the folks in AZ and surely elsewhere.
Xer0449
174
59
I keep hearing that "there's nothing to gain past e30", but right now the car is on E50 and feels incredible. I also run my tank down disgustingly fast.
We're still trying to keep it consistent. That phantom knock bullshit is beyond annoying and we keep running into it.
Posting up some new logs, too.
VACust
112
53
US - Utah
I’ve always read there is not much if any benefit going over E50-60
Xer0449
174
59
The fuel-it ECA+app does a nice enough job of calculating your fill ups for you.
It's also in anticipation for motiv flex-fuel for whenever that happens on N55 :)
The app could use some love, though.
Jake@MHD
Nov 7, 2016
1,615
2,083
Philly
@jyamona any definitive input or differences between N54/N55 on this subject? ^
No they are about the same. E50ish is more than enough to reach MBT on mostly all setups. Running E85 is more-so just for convenience as the driver doesn't have to worry about blending, etc. I say run MHD FlexFuel :)
Xer0449
174
59
Sure thing! Just waiting for it to release for these DME’s ;)
