Technical Torque Lim 512 - Track Limp Mode Mystery Solved
kayzrx82
110
88
n54 335i
Excellent point which brings a question would it be more beneficial to run an aux wheel well cooler before or after main radiator. I always thought after cause it has cooler air but you made valid point .
Aux radiators do well in the wheel well as you mentioned because the air is generally cooler going to them unlike the main radiator that has to deal with the inter-coolers heated air and the condensers heat rejected from the cabin if your running a/c. For a small core sized aux radiator, it would be better to run the aux radiator in parallel with the main radiator. This is how the BMW PPK aux radiator works. It diverts some of the hot coolant from the radiator inlet to the aux radiator then back to the cold side of the coolant system.
You can run an aux radiator before or after the main radiator but the core of the aux radiator need to be designed and sized to allow all of the flow of the cooling system to pass through without being a restriction. For smaller aux radiators that is hard to do which is why they usually divert a portion of the coolant flow to them.
Another effective way of increasing cooling is to vent the hood. This will lower the air pressure in the engine bay allowing more air through the radiators.
1,923
662
What about maybe just running like the turbos return to an aux cooler then dumping back into the circuit, figure n52 doesn't really overheat so this would be getting rid of the heat from turbos and prob helping rest as well since dumping cooler water into the radiator ?
Jan 31, 2017
411
863
www.hydraperformance.com
2010 135i 6MT
N52 has a much lower specific output and specific heat flux compared to a boosted N54, can't really compare the two I'm afraid...
1,923
662
I get that but I think a large amount of the heat is from the turbos I'm sure the extra fuel being burnt adds as well I am just wondering if taking the turbo heat out of equation and a little more heat while your at it. Big singles usually dont have same heat issues
sirdaft1
75
57
Chicago
The answer is to get rid of the stock snails and convert to ST. I know you said you want to stay with the stockers, but I t’s really that simple.
OR you should downsize your IC because that VRSF Race IC is waaay overkill for the stock turbos and is robbing precious space that would be used for cooling the radiator. I would also recommend cutting larger openings in your fender liners to allow the OC’s to breathe and you should also consider adding ducting to the oil coolers as well.
Jan 31, 2017
411
863
2010 135i 6MT
I had a revelation this morning. From what I can tell, the 1M/PPK aux rad uses the EXACT same core as the stock 135/335 oil cooler. Therefore, seeing as I have gone with a CSF radiator + N55-style oil2water cooler (thus rendering the stock oil2air cooler defunct), I will repurpose the oil2air heat exchanger as an aux rad, plumbing it inline with the water feed into the oil2water cooler for a bit more overall cooling capacity at very little additional cost.
700
I would like to revive this thread :)
I am switching to two oil cooler setup and am sitting now on two stock oil coolers. Can i use those additionally to my main radiator with the stock oil connectors?
Would love if this works out :)
