Single turbo n54 misfire cyl 5
Sep 21, 2021
23
Thanks for the advice. Will get in touch with Levan and do a follow up if anything changes.
Did a full adaptation reset. Car felt a lot better but I could still feel a small mis at higher rpms and boost. Not nearly as bad as before.
  • 2021-10-01 13_21_04 I8A0S Ahmad_i8a0s_ST_GFBebc_750ccPI_E85_26psiMax_v7.bin.csv
  • 2021-10-01 13_35_44 I8A0S Ahmad_i8a0s_ST_GFBebc_750ccPI_E85_26psiMax_v7.bin.csv
135boost
250
Finland
135is
Hi
my opinion is that all is caused by stupidity lean condition, STFT 1 and 2 is maxxed out and AFT is at 17 so for sure
it must hesitate and misfire
just after it start to build boost it start to struggle with fuel, there is STFT scalars what can correct that to a value of 34 where after it run lean. you have AFR after that at 17 what will blow your engine for sure.
that tune is for sure done to work with combined DI and PI and can`t be used withoit pi
lack of fuel is some 50% so it`s not a small quantity..
Reactions: seb.apprenti
