E9X Shocks and strut combo
1,923
662
Deff I am waiting on bilstein b12 kit now ill let you know if I get before your purchase I did not want drop originally was going to do perches I just want to level cause I'm on 19 inch sdc f14s and hate the bigger front gap but I figure the new springs will be better as same rate but linear and I was under impressing if I do dinan upper mounts I will gain travel in rear and front cause of shorter bump stops also you need to get adjustable end links I've been told for front so the sway bar isn't In stressed position which effects ride quality substantially.
1,923
662
Fsd were my other choice I went with the bilstein cause of longevity concerns even though I do 2 to 3k a yr tops lol but the fsd should be little more comfortable either are better then old stock shocks though.
PUTC
206
68
08 335xi
Does anyone know the hardware differences between the i and the xi for shocks and struts? Is there anything that would make it not possible to install?
