Screaminfast's Build Thread - e92 SG 335i - 56K no wai
screaminfast
256
135
Rochester NY
mikecentola.com
07 SG/CR 335i / 17 X6 x35i
Update 8/25/20 --
Got some goodies in from VTT
Pulled my 1-step colder injectors out (L to R is 6 - 1)
Pulled the VC and cleaned up all the chipmunk poop from the engine bay...
Tapped the PCV head ports
Plugged them with 10-32 x 3/16 set screws
Cleaned the whole head surface to get ready to put the VC on...
Got the VTT VC on with loose screws while I figure out other stuff!
b4llistic
119
90
BMW N54
screaminfast
256
135
Rochester NY
mikecentola.com
Small update! 8/29/20
Picked up my VRSF 7.5 Race intercooler from my local cerakoter after having it done in transfer black, their thermal enhancement coating. It’s huge and I know I’ll have to cut up the core support. I had pulled my fan shroud and didn’t realize that’s what it bolts to when I couldnt figure out how it mounted haha
I also found some fraying on one of the injector wires. Going to look into wire tucking them and moving the coil grounding posts along with maybe hard wiring the PR coil pack connectors.
screaminfast
256
135
Rochester NY
mikecentola.com
Update 9/10/2020 -
Installled new Index 12 injectors
PR Coil plugs
Heat colored the fasteners for the coil packs
Test fit the PR coil bracket but figured it needed some spacers so I grabbed some phenolic spacers for it.
Got my VTT Oil catch can kit in with some fancy -10AN banjo fittings!
Next up, I converted the high pressure fuel rail mounts to studs and added some phenolic spacers.
Lastly, I had a local friend clean up my headlight lenses because they were yellowing pretty bad. Still pitted, but meh.
screaminfast
256
135
Rochester NY
mikecentola.com
Update 9/17/2020 -
Did some walnut blasting. Used the two bmw tools + HF blaster + shop vac.
Painted the injector brackets because OCD
Degreased and steam cleaned the block, scotchbrited the head for the intake manifold phenolic gasket.
Stated running the PR fuel pump harness wires and trying to figure out wiretucking the main power wires in the engine bay.
Test fit the fuel rail on the intake manifold and added the VTT throttle body adaptor for the catch cans
Just waiting for some more parts to show up from verocious, mcmaster, amazon and VTT.
b4llistic
119
90
BMW N54
Reactions: screaminfast
screaminfast
256
135
Rochester NY
mikecentola.com
Update 10/10/2020 -
Since I pulled the whole front core support, I finally got a chance to fit the VSRF 7.5 Race IC. I got better hardware from Mcmaster to thread into the radiator support, but I might still add some braces underneath it. Test fitted the custom 3" aluminum lower charge pipe.
Got my Oil adapter plate from VTT, BMS oil filter cap, and had the OFH cerakoted black.
Thanks to help from @bahn I ordered a radium coolant expansion tank and the correct fittings for my Innovate water temp gauge.
Used some permatex high-temp threat sealant and added the fittings I needed to the bottom of the intake manifold. Hobbs switch, plug, 5/32 push-to-connect for ECS boost gauge, and -4AN for TIAL BOV & FPR.
I have a thing for 12pt bolts and nuts. 18-8 stainless nuts for the intake manifold
I wanted to make my own custom aluminum vacuum canister to replace the twin plastic ones. Still have to find where to mount it and add the 1/8NPT ports.
Picked up some new filters from Precision Raceworks to replace the chrome / dirty ones that came with my MMP inlets.
Lastly, started working on the engine wiring harness. Separating the various sections so I can remake them with better wiring and extend them to put the DME inside the cabin.
More to come soon!
Reactions: seb.apprenti
Cruizinmax
128
73
09 335i
Honest question, did you mount the coil bracket upside down intentionally? I've seen people do it both ways and single turbo guys complain it hit the turbo when mounted like yours. I was just wondering.
derekgates
740
375
NW FL
derekgates.us
2011 335is
I freaking love this! That is such a great idea, not only for temps.... but looks!
Oh yeah, that's awesome. I was chatting with @GhostRiderCanada about solidifying the vacuum tanks into one unit for packaging reasons... and frankly, looks, cause that looks so much better than the alien pods from BMW.
screaminfast
256
135
Rochester NY
mikecentola.com
Its upside down? LOL I have no idea. They were hitting the tops of the coil plugs so that’s why I spaced it up. How is it supposed to go?
screaminfast
256
135
Rochester NY
mikecentola.com
Nice. Yeah the stock ones look terrible and they are prone to cracking. Once I get the bungs welded on, I’ll have it cerakoted black also so it disappears.
  • Love
Reactions: derekgates
Cruizinmax
128
73
09 335i
I thought the bracket got flipped over and the coils mounted below the bracket. This image was from the PR website.
