RHD Single Turbo Bottom mount setup
rev210
242
146
335i - 08 Coupe .
V8 Bait start tune ready for fire up this Friday.
Martymil buttoning up catch cans, MAC, vac ports to manifold, wastegate and big bubba.
Fingers crossed things hang together.
It will be a total weapon. You 'need' to get the traction setup sorted while you are at it dude. Take down some recordsšŸ˜šŸ‘
Reactions: martymil
We are going to go roll racing and break some hearts and chop off some big heads out there.
This thing was a freaking weapon before, cant imagine what it will be like now.
Only the catch can outlets left to go, still trying to figure out if we go vta on both cans or factory style hi/low setup.
Then the liners, bumper and under trays left and its ready for Friday startup.
135i2
98
98
135i
Cheers. She's been a wild ride on the stock donk even with the full M3 rear end and Trofeo R's. We've had a mighty time with our endless tuning logs.
I might hand it over to Marty for a quarter run down the track once I find a trans solution to replace the Nizpro that no longer exists.
Good luck lads. Vids and pics are always appreciated. This build is an N54 inspiration.
Thanks. See what we can do with my luddite web skills.
Its sounds pretty wild with the 4inch exhaust open. Cams should add a little more timbre.
rev210
242
146
335i - 08 Coupe .
I don't need to tell you the Trofeos aren't your next tyrešŸ˜„ mickey Thompson super streets or if you go another RComp on the back( or need a daily tyre for swaps) then get a wide body kit and shove some big ass tyres in there. R888Rs and V70A Kumhos work a bit better than trofeos for straight line stuff V70As work ok in the wet too(I have these all round) .
So nizpro trans ,you had one or can't get one? I love mine
All done
300 km on it, 4 oil changes and around 10 heat cycles so far and its as smooth as butter.
Can't wait to turn it up and see what she can do.
Had a di rail seeping a little fuel from inj 2.
A quick clean of the engine bay and she is good for mike to start gently slapping her around.
Reactions: rev210 and _Calle_
He goes there every week anyway but hell this is the only thing that will handle the power we are aiming for without sending him broke.
With xhp it it should handle 1000nm easily.
I already have another massive project but will need to get this done so we can take it roll racing.
