Im getting over boost now. Probably a clamp rubbing on actuator. I deviated from hose clamps to t bolt clamps
Typical Z4 ownership story, BTW ...After I fought so long to figure out the technique and get it installed I called it quits for the night.
Very nice write-up on a well-made set of outlets! Bet you are happy to get back on the road!
Curious if you considered wrapping? Are you going to relocate coolant tank? I'm hoping I can hold off doing this until we do turbos. Nice writeup!
Just for others consideration, constant tension clamps are a nice alternative to v-band clamps. @BQTuning also turned me on to stainless steel flex couplers.
Yep ... good price. Cap is same part number so no new one needed. Just ordered from FCP. As usual, thanks to Dimitri for figuring this out on the Z4.Looks like rein from fcp for $58.
Do we need a new cap too?
It was suggested not to wrap the pipe since the aluminum acts as a heat sink for the air inside the pipe...that internal air is waaaay hotter than the engine bay air. Wrapping the silicon coupler protects the silicon from damage due to close proximity to the manifold.
I installed these outlets in August with my MMP S3's. I wrapped both the PSP outlets and aluminum relocation inlets in the DEI gold tape. IAT temps seem to be pretty good honestly. I am also still running a smaller evolution racewerks intercooler and IAT's stay right around 8-10 degrees above ambient. I'm not running any crazy boost yet because I'm currently piecing together my fuel set up but so far so good on 20psi.
Where do you live and what is the climate?
I live in eastern TN. Climate is pretty hot and humid in the summer months. Fall and winter are colder but mild compared to the north east where I'm from.
I live in Houston, TX. In winter the IAT is 10-20ºf above ambient...even in traffic. In summer the IAT can go up to 30-40º above ambient in traffic and 20-30º in highway speeds on very hot days.
Is this similar to your situations or are you saying that you are only 10º all the time?
No effect on water or oil temps. I also trimmed the rear engine cowl which seems to help a lot with under hood temperatures also.Did this have an effect on any other temps due to reduced airflow to radiator or anything?
I trimmed mine too and the only drawback is I have to use the wipers even after it rains due to humidity forming on the windshield from the engine heat.No effect on water or oil temps. I also trimmed the rear engine cowl which seems to help a lot with under hood temperatures also.
