Readiness - Catalyst
Jake@MHD
Nov 7, 2016
1,616
2,083
Philly
This toggle is not magic, you will not pass a true emissions test with catless downpipes with or without it. That person was a fluke and somehow got lucky (if true). As I stated above, this function is actually intended to improve catalyst efficiency (when used with OEM downpipe)
UK and some EU emissions tests are based on tailpipe emissions and don't consider monitors at all. My own cars both pass the local testing requirements here just by using the secondary cats alone.
The reason I noticed the oscillating afr was because of this testing. I was trying to tweak the tune to run leaner and give me a better chance of passing the CO2 limits and I noticed the target lambda from the DME was all over. The idea of the oscillation is that it should average out between both banks but I believe the overall effect is an increase in both unburned fuel and an increase in NOx so fixing this should help genuinely reduce emissions.
335iN54
24
It definitely runs on the richer side on idle oscillates between 13.9 to 15.1 confirmed by quite a few users...
699
I am really curious. I have some oscillation going on on idle and light load.
It has been forever now. I am on INA0S.
If there is anything i can test to get rid of this i would love to test (once my engine is back in the car).
When your car is back on the road just send the bin over and I'll apply the same changes I made to my INA0S cars to stop it. I might give you 3 different bin files each with a different fix to see which one fixes it exactly in your circumstance.
Before this becomes a fix that Jake can add into MHD it needs plenty of people testing it.
Reactions: JohnDaviz
KClemente
315
171
E90 335i
Raising the min cat temperature requirement (c_temp_cat_min_lam_adj_act) helped out my fluctuations on my MSD80 whenever I target 1 lambda at idle.
For anyone that runs higher than 1 lambda at idle, raising the cat temperature req is not necessary as you'll be operating (idling) above the max lambda requirement anyway.
I did 3 tests
Test 1:
Target AFR: 16
Fluctuation of 15.9-16
1% dips to 15.8
Test 2: By far largest delta in fuel
Target AFR: 14.671
Fluctuation of 14.2-14.8
1% dips to 13.8
Test 3: c_temp_cat_min_lam_adj_act adjusted and nothing else
Target AFR: 14.671
Fluctuation of 14.4-14.7
1% peaks of 14.8
My "smoothest" idle was achieved by targeting an AFR of 16.0
studio54
70
33
@KClemente Nice, I didn't think about raising my AFR so much because my first intent was to smoothen my AFR for my failed emission test (high CO) and at the tailpipe test a lambda higher than 1.03 (AFR 15.14) is a fail.
I also thought that this 13.8-15 oscillation function took over AFR target values, so in my head we had to fix the idle/low load oscillation prior touching AFR tables, it seems it's not the case according to your tests.
Here my two logs for comparaison (stock AFR target 14.67) :
BEFORE
AFTER
Night and day, even if a bit of oscillation is inevitable I think.
Otherwide and if it could help other people, my tailpipe sniffer emissions passed successfully yesterday, I think it's a combinaison of three things :
- Oscillation fix (those pulsating dips in the 13.8 aren't good for CO emissions)
- low load AFR to 14.900 (equals to a lambda value between 1.01 & 1.02, I wanted to be borderline of the limit of 1.03 to reduce CO)
- E30 blend (to reduce CO too)
Reactions: KClemente
eastsidaz
159
69
08 335i
corbanistan
140
Florida, USA
E93 335i 6MT
If a toggle to stop idle oscillations might be added to MHD in the future, might I suggest that toggles for other catalyst routines (cat purge, cat monitoring, stimulation, etc) be available as options as well, or all-in-one? I'll always disable these things via tuning personally, but for those using OTS maps or those who hire a tuner.
On a different note, I have notice pretty bad idle fuel consumption. I live in a hot climate, and during Covid I had to sit in my dog's vet parking lot during her visit for an hour. I kept the car running with AC on. The fuel it consumed idling during that hour was higher than I've ever seen in any other car. And sure enough oscillations were happening that whole time. So I believe these routines are definitely having an effect.
corbanistan
140
Florida, USA
E93 335i 6MT
Just wanted to add, last night I loaded on an updated tune with some of the changes mentioned in this thread. Leaned out AFR at idle. Idle is much smoother and quieter. Oscillations seem to be gone on my end too.
Reactions: carabuser
335iN54
24
I have missed that smooth stable idle since I went catless.
It amazes me how majority of people do not notice the idle smoothness degradation on catless or maybe I pay too much attention to the details!
I have also noticed a bit more soot build up in the exhaust, dps and on O2s tips that might relate to that extra unburned fuel from the toggles...
corbanistan
140
Florida, USA
E93 335i 6MT
Yeah that's to be expected from being catless. Everything's perfect for me now after this. Only thing I get now is a single stumble at idle once in a while. Doesn't change anything really but it annoys me regardless! Will eventually replace O2s, sparks, and purge valve as scheduled maintenance soon anyway, we'll see if that fixes it.
335iN54
24
I did have few stumbles on cold start on ngk plugs, switched to bosch n55 plugs and its sorted...
corbanistan
140
Florida, USA
E93 335i 6MT
Hmm I like the NGKs but I think I might have them gapped too small. I've heard the recommended gaps for tuned are just a little bit conservative and can be a little larger. May try that first.
Dyyd
17
335ix
Not starting a new thread since this question is related to subject.
Does anyone have the info on what was the maximum load (in the load table) where cat readiness can still come on. I remember someone on some forum specifying this but did not find it anymore.
Also great info on the catless rpm fluctuation. I ordered area74 cat sims to see if that cures the issue without other changes. What I noticed when troubleshooted this earlier on my own that the fluctuation goes away at least for a while if every lambda adaptation is reset with inpa.
corbanistan
140
Florida, USA
E93 335i 6MT
There's a few tables you could use but this sounds like what you're after:
IP_MAF_MAX_CAT
"max. MAF threshold for catalyst diagnosis activation"
335iN54
24
Any chance of MHD implementing this change in the flasher?
I am happy to participate in any testing as I run OTS maps unlike most people here which run custom tunes.
Implement what? We're still trying to work out exactly what the magic bullet is for inhibiting this behaviour.
I've figured out a way to patch the diagnostics out completely for my own vehicles but it can't be done via MHD as it probably falls foul of emissions regs. So if people want a method MHD can implement then they need to get involved and test the tables mentioned in this thread.
Dyyd
17
335ix
IP_MAF_MAX_CAT
Hello
What would be the location where to find this in I8A0S and what is the default value? Anyone tested this?
Dyyd
17
335ix
Patch the diagnostics in such a way that they will not interfere with normal operation or in a way you would get the readiness bits set?
