RB external PCV setup
Panzerfaust
635
438
Chicago
E92 335i
@Panzerfaust please post what you find when you pull it off, please.
Will do! I have neither PI nor the head plugs installed, just lots of venting on the high side (3 vent points) and a customized low side similar to yours so I'm expecting better results than most without the ports plugged, but probably not quite the level it *could* be at obviously.
My ports will likely get plugged eventually since I have some internal engine parts I need installed, I just dont know if I want to delay it longer so I can get an M18 VC or go with the plastic OE again. With all my venting I'm not worried about the VC itself cracking anyway, so I don't know if a metal VC will do much more than look fancy and make me change my PCV setup which isnt really what I want to do at this point. However the idea of never having to buy another VC for any reason whatsoever is also enticing.
Panzerfaust
635
438
Chicago
E92 335i
So I know I'm a few days later than promised, but some personal stuff came up the last few days and I had to put my product install on hold but heres the pictures.
This is after probably 18months/~25k miles, with the first 6 months being just the RB kit and then the other 12 being my customized low side and VTA high side, the last ~8 of which I've had the high side venting from several outlets. No head ports blocked. My cylinder 1 is the dirtiest you see here which is in line with what happened when I got my intakes walnut blasted, but the others dont look half bad imo. I apologize for the image quality, it was taken on my phone late at night so lighting isnt great nor is the resolution but you get the idea.
Reactions: SSDD and fmorelli
That's not bad at all. No need for a walnut blast again. What's up with the gooey fluid stuff? Mine did not have any film or residue fluid when I checked.
Panzerfaust
635
438
Chicago
E92 335i
I would assume it's just residual oil/blowby from prior to the external PCV installations, my chargepipe and CP to IC silicone had no oil buildup but my IM hasn't been taken off in quite some time - much more than the amount of time that I've had any upgraded PCV system.
Reactions: matreyia
May 15, 2018
20
08 335xi E92
This is with port injection and pvc kit and dual cans.
Is this with you using the RB external PCV kit and a OCC on both the low-side /high-side? Were other the OCC you used the Mishimoto MMBCC-MSTWO-BK 2-Port Compact Baffled Oil Catch Can I will have to have to order this setup to solve my issues.
High BMS
Low Mishimoto
