Raise your hand if you've blown up an N54!
Have you blown up an N54?
  • Yes
    Votes: 52 42.3%
  • No
    Votes: 71 57.7%
  • Total voters
    123
Nov 5, 2016
615
625
Bay Area
Those are H-beams. Def not what you want for big boost / Big Tq motors. I-Beams or don't bother in my book. Thank god I didn't have H-beams in this motor. Thing would have snapped, and scattered the entire motor making it worthless.The Wiseco rods are nice. I love how a set of 6 2JZ rods are also $700 cheaper than N54 rods.
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Why? Who else is making 900+WTQ by 3200? That is what killed them. Oliver makes very tough rods, and so does Manley, Carillo, etc. I was just pushing too hard down low because I wanted to see whats possible. I'll shift the power right a little bit, and the rods wont be an issue.
Just Planning for the future.
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Yeah definitely don't want to throw a H beam rod in there instead of an I beam in high power force induction application. You can kiss that rod goodbye
  • Disagree
Reactions: kayzrx82
1,285
779
Can someone elaborate as to why I beams are better? I always thought I beams were lighter weight and better in an NA application, while H beams were more popular, but heavier in forced induction.
TWilly
85
18
Tyler
I also was always told this. Why would H beam be a bad idea in our engines?
SlowE93
1,832
Just a plane ticket away !
E93
I'm creating this thread for a few different reasons. I'd like to get a better idea of how many bad N54s there are out there. Maybe it's my own opinion, but I feel like most people are quiet about blowing up a motor. Whether it's embarrassment or covering a vendor's ass.
For those of you who have, please comment with the following info:
  • Mileage:
  • Power:
  • Reason:
  • Now what?
I'll start...
  • Mileage: 120k, tuned since 85k
  • Power: ~600-650whp (MMP Stage 3 twins at 28psi with straight E85)
  • Reason: Low compression on cylinder #3. Not 100% sure why yet. I was having large ignition drops that I tried chasing down by installing a better intercooler, colder plugs, and the PR ignition upgrade. None of them helped. Eventually it started to misfire on one pull and I still sent it. I'm guessing port injection played a roll in the mess as well. All cylinders were at 170psi, except for #3 was at 70-80psi and went up to 120psi when I added a tablespoon of oil.
  • Now what? I'm still deciding. I'd like to find a lower-mileage stock motor to throw back in. Maybe I'll build my current motor over the next couple years.
If you don't want to comment, at least vote in the poll.
Is it possible damage was already there when you were running stock turbos and KR tables ? Who tuned the car AFTER Mmp turbos and PI ? Were KR tables still being used ?
AK135i
117
32
Anchorage, Alaska
2010 135i
My name is Connor, I live in Anchorage ak. Im not positive but im sure my location played a large role in engine number 1, im going on number 2 now.
  • Mileage:42,000
  • Power: 400whp; JB4/MHD, fbo minus intercooler, meth ( single cm10 bung) down pipes, cp/bov, straight pipe exhaust with resonators.
  • Reason: lost compression in cylinders 3,5,6. less 100psi. the rest were around 140psi. Why? im not completely sure, but here are the facts and issues I was having before hand. I had been chasing down what I thought was a pcv/vc issue for about 3 months. During this time car was still running great, just had loads of crankcase pressure, so much in fact It was forcing its self out of the oil fill cap making a huge mess when ever I was wot. Well after a new vc, rb external pcv, it mitigated my symptoms ( smoke on decal, that was all). I went for a little 3rd gear pull with the meth turned on, at this point it was spring so I hooked it back up, after about 3- 3rd gear pulls the car started to shudder really hard below 3000 rpm. it would have a choppy idle, decided to check compression at that point and that when I was blessed with the news.
  • Now what? I bought a crate engine and went single turbo.
4 days after my new engine was installed, the crank bolt backed out and buried all 24 valves into the head and destroyed the entire valvetrain.
I made the mistake assuming my mechanic actually knew what he was doing, turns out he was full of shit, I lost thousands.
I shipped the car to Oklahoma with my remaining savings and Ghassan Automotive is hooking me up with a new engine, thank god for warrantys. Anyways, im flying down to drive the car back with a new engine, I guess I like to take chances, but I couldn't afford shipping it back.
Why did it fail due to my geography? Alaska has the worst quality fuel in the country, a selection of 88,89,and 90 octane values, you read that right, also no e85 what so ever unless you want to drive 1500 miles to seattle. So all us Alaskans run methanol because of this, and race gas is out of the question as its $16 a gallon, and my car is my daily. From what ive read, the stock intake manifold has a hard time distributing air properly, so im guessing 3 of 6 cylinders were gettings 17-18 psi with 90 octane only for fuel. This is all just speculation, I made some mistakes while trying to get a new engine, unfortunately I don't have the skill to swap it myself. I just learned the hard way, and not play with meth.
Reactions: The Convert
m5james
  • Mileage: 125k
  • Power: stock running a BMS DCI and RB catch can
  • Reason: best as I can tell injector #1 flooded the engine, hydrolocked and lunched the piston
  • Mileage: 75k used engine, drove for about 10k...$2k and two weekends wasted
  • Power: MHD stage 1 w/ existing DCI and RB CC
  • Reason: rod knock
  • Now what? Leaning heavily towards a Ghassan Alneama / Ghassan Automotive basic $3500 "rebuild" and crossing my fingers that the upgraded bearings and improved ring gaps will allow a longer engine life. I've got a VRSF 7" IC and silicone inlets sitting in boxes but at this point in indifferent about this motor...I've had bad luck with basically nothing mods wise yet I see and know people pushing low 11's on their DD. I'm also considering buying another used engine locally for $1k that runs fine, replacing the rod bearings myself, pocketing the $2500 saved by not getting "rebuilt" and then telling the GF to enjoy her 535xiT with a simple flash tune and leave it at that because I feel like this engine is an eggshell.
MMP and Ghassan basically do the same $3500 "rebuild" but it's just reusing old parts paired with new bearings and gaskets (not technically a rebuild, that's just a disassembly and reassembly) which is why I'm considering just doing the rod bearings myself and calling it a day since they're a huge problem with the N54 and a handful of other BMW engines.
1,285
779
A huge problem with the N54? I always thought it was the NA M3 and M5 that had rod issues. I very seldom see or hear about rod knock on the N54.
Reactions: veer90 and kayzrx82
  • Mileage: 125k
  • Reason: rod knock
  • Now what? Leaning heavily towards a Ghassan Alneama / Ghassan Automotive basic $3500 rebuild and crossing my fingers that the upgraded bearings and improved ring gaps will allow a longer engine life. I've got a VRSF 7" IC and silicone inlets sitting in boxes but at this point in indifferent about this motor...I've had bad luck with basically nothing mods wise yet I see and know people pushing low 11's on their DD. I'm also considering buying another used engine locally for $1k that runs fine, replacing the rod bearings myself, pocketing the $2500 saved by not getting rebuilt and then telling the GF to enjoy her 535xiT with a simple flash tune and leave it at that because I feel like this engine is an eggshell.
MMP and Ghassan basically do the same $3500 "rebuild" but it's just reusing old parts paired with new bearings and gaskets which is why I'm considering just doing the rod bearings myself and calling it a day since they're a huge problem with the N54 and a handful of other BMW engines.
Where can you find diy on bearings abd such?
m5james
Having looked specifically for examples of it, it's all I see now...plenty of threads on N54Tech, Facebook N54 pages and a handful of YouTube videos.
m5james
I'm in the very beginning stages of research about doing them myself and I've yet to find an N54 specific rod bearings replacement video. I've removed the oil pan, replaced bolts holding on the oil pump (LONG story but one used engine had the same issue as as this first video where the oil pump bolts has snapped just not been ingested yet), so hopefully changing the bearings will be like in the last two videos...just easier being on an engine stand. I just figure I'm gonna try and combine what I've seen in these videos and hope for the best via using bearings with better coatings and not such tight tolerances.
Milan
413
241
jebi se
your mom
No they wont. you can quote any internet article you want. I site real world experience.
We make 1200 whp on the budget Chinese H-beams in the LS world every day! Honda guys have pushed 900 whp on Eagle H beams, those are about as cheap as you can get.
I beam is definitely better but I wouldn't count out H beams as a blanket statement.
335i_nick
98
43
Had to change my vote, I sent my first N54.
3 bent rods and 1 cracked piston. tons of blowby lol
