DIY : PTFE line- tank to HPFP + inline fuel filter upgrade
NoQuarter
1,662
1,066
Indiana, USA
Z4 35is, 535xi, X5 35i
I'm going to get in on this too. I have an ethanol sensor in place already with upgraded fuel lines. When I adapt that to the flex-fuel system I will put in a new filter then remove the one from the hpfp.
Reactions: Blaster3500
This is what I used but use it at your own risk
Should only be installed by a competent mechanic
HPFP Adapter 171-06-14-BLK
Sensor adapter 140-06-BLK
Push lock hose adapters x2 401-06-BLK
30cm of aeroquip 3/8 fuel line depending where your connection is and type
Thread sealer or gas plumbers tape for the sensor
Lifestyler
69
World
135i
Have the hpfp adapter the Same cone INSIDE Like the OEM hardline have to Connect on the hpfp ? Or is it a flat surface on the M14 Side?
I like the op's ptfe setup might use this for my new setup but the new kryptalon from aeroflow hose
Extremely flexible but very expensive
BOosted 335i
315
104
New Jersey
E90 BMW 335i
Thanks for the info!
4,345
Question, can you show me a photo of the female fitting which has the cone inside? The HPFP inlet is M14 1.5? What angle is the cone inside? I have a pair of these for my shotgun but they are separate inserts, ferrules or whatever they are called.
I saw this, but that is not right, you're missing the cone inside? There is no seal without the cone I think.
171-06-14-BLK Looks like that
If your going to put this fitting on the shotgun make sure you use a mild locktight on the thread as it vibrates a lot and it can come off
1,630
I think most of us can use a short course in “Fittings 101”.
(I used to work in a chemical engineering lab many years ago, where we had many boxes and containers and catalogs of all different kinds of fittings for different purposes. It seemed that there was a lot of hit and miss rummaging around in the parts bin. It’s amazing I didn’t blow anything up!)
Reactions: The Convert
