OneLap1M (aka "MDORPHN")
4,342
Oh poo. I suppose that makes a lot if sense though, for some reason I forget there are human organizers and others.
Reactions: Asbjorn
twinturbos
291
79
E92 335i MT
Do you have a picture of the routing of your brake ducts ? aswell as how it blows into the discs?
sancho78rus
32
31
Russia
e82 135
3 degrees camber, 0 toe. Good eyes -- camber plates were installed backwards, that since been corrected so I can run max caster!
Only running brake cooling from inlets on either side of intercooler.
Neil
As I can see on FB, you are running on slicks.
You should definitely try much camber. I definitely felt the benefits going from -3.5 camber to -4.5 on front. Now testing -5.
What is your caster now? What is the rear camber and toe?
Did you tried toe out on the front?
