Oil Cooler Delete
Na thermostat can get its water from the tank,from the heater core, and ofc from the rad, but let's agree to disagree.
And this particular system is used on N55 newer than our N54, so no bmw didn't scrap it.
The new B58TU uses a oil2water exchanger, a way bigger one tho...
All coolant MUST flow through the radiator and any coolant that is not in the radiator when engine is off will be stuck in the channels of the motor, ofh, heater core and the expansion tank. Naturally during the transit process, the coolant will travel through many stops before reaching other stops... example, radiator flow to heater core then to ofh then to motor, then to turbos, then to waterpump then through thermostat and back to radiator. The trip is a one way trip and does not distribute itself from multiple places as you state: "thermostat can get its water from tank".... if it did that, the whole purpose of the thermostat to monitor and regulate motor, turbo heat would be defeated because the expansion tank is always cooler than the rest of the sections and therefore would give rise to errors in thermostat/motor regulation.
The expansion tank serves to give coolant if it is low, OR release overflow if it is present. It does nothing to regulate temperature relating to the thermostat. Also, the heater core is not a radiator, but rather it collects heat from the coolant to use if the driver wants to heat the interior... otherwise, it does very little to reduce heat from the coolant as it is hidden from air flow almost completely.
The Convert
1,487
1,053
Three drunk guys are leaving the bar to walk home after a long night of drinking. When they get to the middle of the bridge they have to cross they stop to take a piss. While they’re standing there pissing, the first guy says, ”Man! The water is cold.” The second guy replies, ”It’s deep too!” Then the third replies, ”and there’s gravel on the bottom.”
So, when you three are done trying to decide who’s dick is bigger, let us all know.
Traf
362
206
135i
Can't decide between keep explaining or insulting that other idiot.
Just to make it clear, nobody said the heater core was to reduce heat, but whatever.
Please take a closer look at the plumbing... You probably will notice a few things.
1,152
1,202
Scottsdale, AZ
If you want a simple Oil Cooler delete just let us know. We have all the parts in stock. Order the block off plate, with -10 AN fittings, and email us we can charge you for the female coupler or you can get one yourself.
Chris
It's actually just a guess on my part. The flow direction could be totally backwards. In any case, the expansion tank serves to allow the coolant expansion pressure to be relieved to prevent damage to coolant system.
Traf
362
206
135i
True, but during warmup, which is what we are talking about. If you open the expension tank you will notice water being sprayed into the tank by the small hose that runs on top of the radiator. Which comes directly from the hot side and bypasses the rad. As for the heater core, i don't know if water is flowing through it all the time or just when you request heat. But when its flowing, it is also bypassing the main rad.
mcleansc
111
101
E92 335i
Chris
This is exactly what I was thinking of doing, thanks a lot for chiming in its appreciated. I already placed an order through Rob Beck for one of his plates this morning . Again though thanks for the help.
The vendors representing the N54 community really are awesome, very quick to lend advice and help to someone who may or may not make a purchase.
And cheers to everyone else for chiming in with info regarding the cooling system.
Oct 24, 2016
1,152
1,202
Scottsdale, AZ
Keep in mind it just happened to work out with our plate the holes are exactly the right distance apart to allow this to work. We were not sure it was going to until we tried it on the shop car. If the holes on the RB plate are closer together or further apart the coupler will either not seal or will put too much strain on the fittings, and could cause issues. Just be sure to test fit everything before startup.
Reactions: mcleansc
mcleansc
111
101
E92 335i
Cheers for the heads up, my initial plan was 2, 90 degree fittings and a short length of hose betwinxt them. I dont think Rob's are in the same location as yours which is a bit of a pain as that looks really neat, but hopefully should still work as well with the hose.
mcleansc
111
101
E92 335i
Chris
Hey Chris. Sorry if this appears cheeky as I didn't actually buy your product but looking at the pics it looks like the RB and your plate do have at least similar mounting positions for the fittings. I gave the plate to my mechanic (in February!) and he still hasn't managed to loop the ports like you. Could you tell me the length of your female coupler? He's went a different route that apparantly involves having a fitting machined which sounds a bit ridiculous.
Happy to send over beer monies as a token of appreciation mate.
Cheers
