Hey everyone, I wanted to share our product in case you haven't been made aware through Facebook.
I’d love to hear what you think—has anyone here used Epoxy54 before, or have questions about how it works?
epoxy54.com
What is Epoxy54?
At its core, Epoxy54 is an epoxy designed to reinforce the aluminum engine block, similar to a block guard, yet easy to apply and budget-friendly.Why Epoxy54 Works Better
- Traditional block guards are press-fit into place, and they need a lot of machining. This can be complicated and often leads to cracks over time due to the thermal expansion rate differences between cast and billet aluminum. Additionally, pressing a tight tolerance piece into a roughly machined surface such as the water jacket can cause bore tolerance issues.
- One of the coolest things about Epoxy54 is that it expands and contracts at the same rate as the aluminum in your engine block. This is super important because mismatched expansion rates can cause warping, which leads to bigger problems down the road.
Why It’s Better Than Cement Fillers
While cement-based are ideal for cast Iron blocks, they come with a major downside: they don’t expand at the same rate as aluminum. This mismatch can create stress points that cause the engine to fail prematurely. Epoxy54 doesn’t have this issue, making it a safer bet for long-term durability.Easy to Use
Now, if you’re not a professional engine builder, you might be wondering about the installation process. The good news is that Epoxy54 is super easy to apply—even for beginners. You don’t need a machine shop or specialized tools. It’s DIY-friendly and doesn’t require major modifications to your engine block. You can apply it before or after machining without messing up the engine’s tolerances. See the installation video guide below:Cost-Effective
This is one of the best parts about Epoxy54—it’s affordable. No need to pay for expensive machining or specialized installation. Plus, it’s way cheaper than most block guard setups, which require a lot of time and money to install properly.Real-World Success
If you need proof of how well it works, Epoxy54 is currently used in the motor that holds the fastest N54 1/4 mile time at 8.16 seconds and 168 mph. This is a high-performance engine running in extreme conditions, so you know it’s durable and reliable.I’d love to hear what you think—has anyone here used Epoxy54 before, or have questions about how it works?
EPOXY54, The Aluminum Block Epoxy Kit
Why Choose Custom Epoxy for Aluminum Engine Blocks? Key Benefits of Our Custom Epoxy Formula: Permanent Bonding: Specifically designed to adhere permanently to aluminum. Reduces vibration, minimizing cracking risks and eliminating false knock issues. Thermal Compatibility: Engineered with a...
