No boost after firmware update
Bmwfixerguy1
875
292
07 335i MT
So I was running 32_2 and updated to 32_10
After which can't make over 3 lba of boost. Now this is a well documented issue after updates and one everyone likes to say read instructions ECT ECT.
Well I went over every single possible setting and can't find the issue. Duty bias stayed the same, I don't see any major changed and if their was a special instruction when say 32_4 came out they deleted that on the update page..
Any help would be great I'm flustered with it..
@Terry@BMS
Terry@BMS
Jan 23, 2017
464
380
A log is the only useful piece of information to provide you with any assistance. :)
Common problems are failing to set duty bias all to 0 (if no custom duty bias tuning is applied), setting menu4 in dash to the wrong mode (stock flash = 3, back end flash = 2), somehow setting FF (global dutycycle scaling) to 0 or some really low number, etc.
Bmwfixerguy1
875
292
07 335i MT
Here's a log, I know I'm missing something simple that I couldn't find
Note I was running 32_2
  • 2017-12-12 20_41_40.csv
Bmwfixerguy1
875
292
07 335i MT
I can after work..
What do you mean you don't see a meth signal? I looked on my previous logs and meth all settings appeared to be same?
I'll check menu 12 but I messed around with it a tad and no difference IIRC. I did notice my target stuck at 9.9 psi???
Bmwfixerguy1
875
292
07 335i MT
Please tell me how she looks.. because Good golly Mrs Molly if this is bad I don't wanna right.. most I've thrown at her since the new turbos!!
  • 2017-12-13 17_33_58.csv
Terry@BMS
Jan 23, 2017
464
380
Yes everything is looking good here.
What is menu12 set to?
For kicks try map3 again on a 60 additive to see if meth flow or boost come up on it.
Bmwfixerguy1
875
292
07 335i MT
I will.. I was so excited and planned on trying it but my belly wanted food more than I wanted to know lol..
I turned 10-5000 (had set to 0 idk why)
11-2500
12-2500
Now I remember, with 32_2 Everytime I adjusted 12 it would be back at zero when I checked because after I turned FF off.. I believe I statey this time where I put it.
I can't believe this car has more left in it my gad it's was a violent lol!
Bmwfixerguy1
875
292
07 335i MT
Lots more. Relog the 60 additive next and we'll go from there.
I will get back to doing that it started to sleep outside.. but the meth flow staying at 56-57 is that another setting? It's way cooler that 44 deg.. it's about 22 deg out and I always pull right to damn near ambient temperature.. any thoughts.. I have a lot of reading up to do and understanding of the new meth stuff you have added.
Bmwfixerguy1
875
292
07 335i MT
Meth signal seems OK to me at the moment.
Shouldn't meth flow equal 100? I always when form 0 to 100.. is this the scaling adjustments that need to be done? I read over a lot of the revision notes bit am missing 32 3 to 32 5 so don't know if anything in that span needs to be done. Seems like a lot of meth control update options
Terry@BMS
Jan 23, 2017
464
380
No, 60% or higher is full flow, as indicated by the meth flow scaling = 60 in your datalog. As I said I'm not concerned with your meth flow at the moment seeing it on map7.
