Nightmare diagnosing n54
Msport335
116
26
They are new index 12s and the rough idle is not from a leaky injector...those feel like irratic hiccups which sometimes trigger misfire codes. This rough idle is different and sounds in line with the compression stroke of the motor. No white smoke out the exhaust...just coming out the oil cap when I open it and some out of the catch can vta side
iminhell1
419
207
Depending on pressure and amount, that tends to be a cracked ring.
Compression test should reflect/confirm this. You should see one cylinder down quite a bit vs the others. Lets say a 20% difference in 1 cylinder. So if you have 5 at 190 (which is what you should be near) then 20% loss you should see one around 150, or lower.
But with the sound you describe I would think you'll see one below 100psi.
Reactions: fmorelli
Heyfred
61
74
2007 335i
If it was a cracked plug wouldn't it throw misfire? The rough idle is also not from a bad injector... it sounds like its got a high lift/duration cam in it now
Big cam sensation = Vanos sticking.
iminhell1
419
207
Totally normal smoke.
I don't head anything that sounds bad either. No big cam sound and normal sewing machine injector ticking.
So whatever you have going on is intermittent. That rules out anything piston related.
Might be vanos related, but that should throw a cam position error.
Msport335
116
26
You can hear what sounds like the big cam at the back of the car out the exhaust. The idle while sitting in car sounds lumpy...something is up. This smoke only started a few days ago so I wouldn't consider it normal. Definitely smells when driving around now too
S54ca
28
31
The oil vapor venting from the cap appears excessive. Compression or leak down test should be the next step, IMO.
Heyfred
61
74
2007 335i
Is the PCV valve internal or external hooked up to the catch can?
Heyfred
61
74
2007 335i
What Milan said: Vacuum leak. For test purposes, remove the IN hose to the catch can, plug it off and see what happens.
