when will the stage 4 be for sale ? I need something within a month's time
Can anyone tell me what this little plastic disc is for? It was in top of the filter (option 1 filter, the maxipad looking one)that attaches to the pump. Seems to get in the way. I took it off and the filter attached just fine and tight to the pump. Is this needed? Do I need to go back and install it?
Copy that. Went back in and installed it. All is good now. Thanks for the reply.Yes you will want to install that.
There is an output on the bottom of the pump that can cause the filter to lose suction if it's not installed.
Much better flow. I can see a huge improvement. Thanks fuel it!
If you haven't picked something up, shoot me a PMwhen will the stage 4 be for sale ? I need something within a month's time
Thanks for the info. This post helped make up my mind. Bucketless it is.
I wish my stage 3 was upgradable
Happy to help whenever you are ready.Might have to get his or just go stage 3 or 4. Maxing out my stage 2 but it has been great. Glad there's more options now
With or without the hydramat?Happy to help whenever you are ready.
I've been using the stage 2 bucketless with my Pures & PI kit- it hasn't skipped a beat
All of our stage 2 bucketless upgrades come with our standard fuel filter.With or without the hydramat?
Our stage 2 bucketless outflows a standard stage 2 with bucket by about 27%.Just out of curiosity, how's the reliability of the pump unit itself? I'm FBO on a mild tune, but I'd like to be able to run E-40 eventually and to make sure I'm covered as far as fuel supply.
If you plan to run e40, you will be more than covered. Many are using our bucketless pump, supporting upwards of 600 whp on varying levels of e85.
