Need coding advice on LED fog lights and taillights
Stevae
I recently changed the fog light housings on my E92 335i. Not the LED bulbs, but ONLY the housings they were in. And yet, I am getting alarms from the car every time I start it. Now, I have ordered some LCI taillights, and would love to know how I can code my system to STOP actively pursuing those codes. I am not familiar enough with the different coding platforms to know which one codes to stop those. So any help is very much appreciated.
screaminfast
256
135
Rochester NY
mikecentola.com
07 SG/CR 335i / 17 X6 x35i
It's pretty simple. You just need to set the bulb checks to nicht_aktiv using NCSExpert. I would assume something like protools can do it as well. Do you already have a cable?
Stevae
I do have a K+Dcan cable. I can look at and clear codes in MHD, as my car was custom tuned with MHD before I purchased it. But I can't afford MHD right now. So I'm limited to that. I will research NCSExpert, to see if I can use it. I've never heard of it. But I truly appreciate your bringing it to my attention.
screaminfast
256
135
Rochester NY
mikecentola.com
If you have the cable, you can get BMW Standard Tools over on BG: https://www.bimmergeeks.net/downloads
There are plenty of videos and documents on getting it installed. I have it installed in a VirtualBox VM so I can use it. The other option is to just get something like BimmerCode or ProTool app and do it from your phone or tablet.
