N55 vs S55: Technical Differences, Compatibility & Performance Potential
Boorda
164
82
Royse City, TX
futemire.com
328xi, 335xi M Sport
I'm starting this thread to have a centralized location to reference technical deep-dives into the differences between BMW's N55 and S55 engine platforms. My goal is to create a comprehensive resource where we can discuss compatibility between parts and potential performance gains when upgrading or swapping components between these platforms.
Check back regularly as I will do my best to maintain this first post with shortcuts to various posts and resources.
Technical Documentation​
N55
  • Technical Training
S55
Other Resources​
N55
S55
Technical Differences​
Below are technical key differences between the N55 and S55 engine platforms.
This section also includes updates and variations within the N55 and S55 engine platforms themselves.
Between engine variations of the same platform, it is assumed that everything in the previous version is identical unless otherwise specified.
Items marked `Unconfirmed` are believed to be true but research is being done to officially confirm the claims.
Block & Engine Externals​
N55
  • Initial Release
    • Cast iron cylinder sleeves
    • Single HPFP
    • Single Oil Pump
    • Pneumatic Wastegate (PWG)
  • M2 Variant
    • Dual Oil Pump
  • Update 1 (2013-2018)
    • Upgraded oil cooling - Unconfirmed
    • Electric Wastegate (EWG)
S55
  • Initial Release
    • Closed-deck design
    • Stronger cylinder walls
    • Plasma-transferred wire arc sprayed cylinder liners for improved strength and heat dissipation
    • Dual HPFP
    • Dual Oil Pump
  • Update 1 (2015-2020)
    • Oil Pan Upgrade (Material) - Unconfirmed
Questions:
  • Can you swap an S55 into and E92?
Engine Internals
N55
  • Initial Release
    • Cast Rods
    • Cast Pistons
  • Update 1 (20xx-20xx)
    • Forged crank - Unconfirmed
    • Forged Rods - Unconfirmed
S55
  • Initial Release
    • Forged crankshaft (4-6 lbs. lighter)
    • Forged connecting rods
    • Pistons with Teflon coated side skirts
Questions:
Cylinder Head​
N55
  • Initial Release
    • Working on
S55
  • Initial Release
    • Working on
Questions:
  • Are the cylinder heads interchangeable between the platforms?
  • Does the S55 head flow better?
Turbocharger Setup​
N55
  • Initial Release
    • Single twin-scroll turbocharger (Brand(s)?)
S55
  • Initial Release
    • Twin single-scroll turbochargers (Brand(s)?)
Questions:
  • Can N55 owners use S55 turbochargers? What modifications would be required?
Electronics​
N55
  • Initial Release
    • DME: MEVD172
S55
  • Initial Release
    • DEM: MEVD172G
Questions:
Question Queue​
  1. What's involved in adapting the S55 cooling system to an N55?
    • Not Possible
871
Thanks for putting this together!
A comment about the rods - this may depend on year of n55, but per realoem, the rods in my n55 (2015 e84 n55 with pwg) cross-reference to the s55 engine. Anecdotally, I've heard they changed the rods after the earliest n55's (2010 and potentially 2011?)?
Reactions: Boorda
Boorda
164
82
Royse City, TX
futemire.com
Perfect, thanks for contributing!
I'm actually working on an AI Agent specific to searching through RealOEM to find nuances like this.
You'll also be able to ask it questions and it will make comparisons and pull the info for you.
871
Wow, that sounds awesome, thanks again for pulling this all together, great resource for the community!
Reactions: Boorda
871
Totally anecdotal, but I've also come across comments that after initially launching s55 with the magnesium oil pan, bmw switched s55 to an aluminum pan somewhere along the line. Maybe that's something an AI tool could identify/confirm/denyšŸ‘
Ali_X
10
I also believe and correct me if I'm wrong but the N55 EWG produced from July 2013 installed on the 235, M2 and x4 40i (N55 engine) has a forged cranckshaft and a revised cooling system and oil pump regardless of xdrive or not.
Only the M2 and 235iR have the S55 oil scavening system (dual pump, sump)
Boorda
164
82
Royse City, TX
futemire.com
I'll modify the first post so that we can start to capture engine revisions for each platforms as well.
Reactions: Ali_X and wheela
