This looks great!! Can't wait to see results on this
Awesome build, cool to see the N55's getting some love.
Very cool, to say the least.
Fingers crossed! I will not have any issues related to that.Very nice! I would really love to do a built motor once all the misfire/knock is figured out.
If I'm not mistaken, the only difference is the water pump installation because the turbo sits lower and the turbo housing is bigger on the Speedtech kit. So, the water pump needs to move forward. However, the water pump remains in the stock position on the Bigboost kit.So, I wonder how the Big Boost and Speedtech kits compare in terms of install...
You are very lucky!I was able to get a pd setup and was told that I could still send my transmission in
A few more pictures before the motor/trans goes back in the car.
More to come
Any updates? Link to all work and parts used on just the engine build? I'm curious about pistons / rods, new compression ratio, different head gasket / cut ring, valvetrain mods, etc...looking great man.
I'm probably going to do some kind of build with N55 from my M2, but I am wondering what the differences are between my engine and a standard N55. Rumor was there are s55 internals, but I have yet to see any confirmation. I'm hoping to do a docrace turbo kit. I just don't know if I should build motor first, or let it pop on its own.
Thanks. I was told that the f87 n55 has the s55 rods & pistons. I trust you know what you're talking about, so thanks for this info. Would weisco pistons and eagle rods work? If not, what are good options for 800-900 rwhp?Engine difference is the crank. Forged vs cast. All else is the same pretty much. Over 650whp do rods and pistons.
Thank you for that info. With that being said, can I get some advice regarding the proper recipe to build my F87 N55 for 800rwhp?All N55's and the S55 have the same rods. M135, M235, and other E/F series N55 except M2 have the same pistons.
As for the N55's with the forged crank, here:
Part 11217602972 was found on the following vehicles:
1' F20 (04/2011 — 02/2015)
1' F20 LCI (06/2014 — 06/2016)
1' F21 (12/2011 — 02/2015)
1' F21 LCI (06/2014 — 06/2016)
2' F22 (10/2012 — 06/2016)
2' F87 M2 (11/2014 — 06/2017)
2' F87 M2 LCI (09/2016 — 06/2018)
2' F23 (03/2014 — 06/2016)
7' F02 LCI (05/2011 — 05/2015)
X4 F26 (11/2014 — 03/2018)
MS BMW Motorsport ( — )
