Adding my post to this thread, so it doesn't get buried. Maybe
@doublespaces can add it to the first post?
Original thread:
https://www.spoolstreet.com/threads/bosch-spark-plugs.5839/
They're definitely not the same. The 7 indicates the heat index, which is 1 step hotter(!) than the N54 OEM Bosch plugs (ZGR6STE2). NGK 95770 are about one step colder than OEM N54. You'll want some Bosch with an index of 5 for the same heat index as the NGK 95770 (ILZKBR7B8DG - NGK's heat index 7 equals Bosch's 5). For Bosch plugs the lower the number, the colder they are. NGK it's the opposite, the higher the number of their index, the colder the plugs.
Both ZMR5TPP330 (OEM S55 and M2 N55 - the M in the name indicates they are for M cars) and ZR5TPP33-S (OEM N55) are not produced anymore and superseded by ZR5TPP330 and ZR5TPP33 respectively. Production ceased 01/19 and only remaining stock is sold.
ZMR5TPP330 vs ZR5TPP330 = the center electrode's diameter is different -> 0.8 mm vs 0.6 mm
ZR5TPP33-S vs ZR5TPP33 = interference suppression resistor is different -> 8 kOhm vs. 6 kOhm
Other than that, the spark positions of all mentioned plugs are different!
Spark plug | Spark position |
NGK 95770 (ILZKBR7B8DG), ZGR6STE2 | 5 mm |
NGK 97506 (SILZKBR8D8S), ZR5TPP33-S, ZR5TPP33 | 6 mm |
ZMR5TPP330, ZR5TPP330 | 7 mm |
Sorry if any termini aren't exactly right, I had to look up some words
