N54 surging feeling coasting or light throttle
Slowagon54
207
96
I had the same issue mate. My car is 3 years old and only 50k miles on it. See the injector pics i posted at the B48 Engine section... you wont believe this. One was leaking (inj. 2) and one was kinda burnt (inj. 4). But i did not notice anything else beside the bugging on light trottle while cruising on the Autobahn. Of course the engines are different, but the issue is the same. Anyway, if they are all Index 1 you just have to change them. It s already been 12 revisions on them since... :)
2,198
This.
Reactions: SLOWESTN54
LazySoo335i
13
Strange that readiness is passing but the diagnostic is still causing lambda stim.
Generate a stock bin from MHD and upload it here. I'll patch out the lambda stim and also check the region specific stuff like DMTL.
Here's a copy of my bin
  • WBAWB73517P022284_updated.bin
LazySoo335i
13
I have a set of new to me index 8 injectors on standby I could try out, see if maybe I can isolate the problem. Never put them in yet because I figured if I couldn't tell that my injectors weren't working properly then why swap them out yet
