Wide open throttle, aka pedal to the metal.
Oh I didn't know that ! But I know how to do it !
Just curious if the maps will adjust to a middle % like E73 or would it just tune to E70 or E75 at that point?
That's bad ass!It will adjust to a seemingly infinite amount of blends. It has the resolution to interpolate at the 0.39% level.
That's bad ass!
Okay, I have a stock fuel system with a Warblo 450 fuel pump. Anyone know about how much E85 this can handle?
Asking for a friend![]()
It's pointless to run above E50 on the OTS map as boost will start to taper back towards pump gas levels above it. If you plan on regularly running above E50 and want more power, I suggest a pro-tune.
Why will the boost tapper back ? I tought E85 had higher octane rate than pump gas, so what's the technical reason to not go over E50 ? I'm learning![]()
It does indeed, but the stock fuel system of the N54, or even Stage 2 LPFP upgraded, can't keep AFR's on safe levels with pure E85 as it's energy content is lower than pump gas -> you need more of E85 than 93 to get the same amount of energy out of them and the stock HPFP can't provide enough of it to take advantage of using only E85 AND extract more power from it as you could if your fuel system could keep up.
Therefore E50ish has the best octane/energy density/volume for a Stage 2 LPFP and stock HPFP fuel system to get the best power output with these restrictions in mind.
Nice looking log!Quick pull of E42 2011 335is DCT https://datazap.me/u/noguru/quick-pull?log=0&data=3-21
Yeah, this is after about 1/4 tank burnt through.Nice looking log!
I noticed the boost was not smooth upon spoolup. Had you done a few pulls prior to this one?
Here's an E36 log : https://datazap.me/u/hillntoe/e36?log=0&data=3-5-20
Ok now that's totaly clear, thanks for this great explanation. So E85 is possible with stock HPFP and stage 2 LPFP but I'll get less power than E50.
I am tuned for 100% E85. (Turns out to be E80 out of my local pump)
I have an upgraded LPFP and lines but otherwise stock fuel system. So, I am tuned for 100% E85 based on what my fuel system will support, not based on trying to get maximum power.
Thanks.Looks great. Just one timing blip while shifting on cylinder 5
