N54 HPFP VCV Tables
BloodyZ4
56
37
Germany
Z4 35i DCT
some hpfp stuff to make you happy :joycat:
naming is pretty self explanatory...
dont blame me if your hpfp blows up... you have been warned
Could you or someone else define the HPFP stuff for INA0S when you find some time?
Wanna get rid of the cold start chatter since I installed the PFS POD today.
Winny_N54
15
Hi @mj6234 ,
I have a similar issue like you. My config is:
  • Stock turbo 18psi
  • Walbro LPFP 525l/h
  • 30, 40 or 50% of E85
  • JB4 BEF RACE
  • Not equipped with helix
  • Stock values in HPFP tables xdf
At Idle, i have my HPFP going up to ~1800Psi with my afr which turns to 15,6 some ~5 second, then my hpfp goes back down to its initial value of 750psi idle. My pump also knocks for a few seconds. I'm afraid to damage it.
I only have this idle pressure problem with mixture e85, not 91/93 octane.
It's impossible for me to extract the logs because I did it with JB4 Mobile and the log extraction function doesn't work on my Xiaomi 12.
Were you able to solve your problem ? :pensive:
iTurbo
Euro E92 335i
hello,
does someone have the rail pressure cold tables for ia8os in an xdf? or have i overseen it?
greetings 🙋‍♂️
bernardo774
22
11
hello,
greetings 🙋‍♂️
I have for IJEOS, you can use for start point
keninger
72
14
335i E92 N54
0x46464 with a conversion of (X*5.306721599145)*0.014503773773 stock should be 580psi
Do you happen to have a definition for (C_FUP_DIF_CUR_VCV_AD) Max fuel pressure deviation to allow adaptation for I8A0S?
