It's 2024 and spun crank hubs are still a problem, perhaps even more so than before with the age of the N54.
Car is 335i 06/2009 build N54 with DCT - RHD M sport. It's essentially the same as a 335is.
I'm tossing up between:
* VTT V2 Splined Hub
* INSANE 4 Pin Hub
Both have their pro's and con's. What would you choose and why?
VTT V2 - easy install, no need to remove sump etc and it's more or less a factory fit with friction washers aiding in the prevention of slipping.
Pinned hub - harder to install - risk of metal shavings due to drilling - pins have been sheared before and there's no friction washer's to take the load - just the pins themselves which are in constant shear.
What I'm looking for is to solve the crank hub problem once and for all as I drive my car hard and track days are on the horizon. I'm not looking to turn it into a full blown race car as I have a JZA80 Supra for that - but I want to have that reassurance that if I do a 2 day mountain run with friends or a track day on street tires or semi slicks, it's not going to be an issue.
Is the VTT V2 crank hub as good is Chris says with no failures etc? If I choose this I will do the complete solution install with CBC, new bolt and the like.
* INSANE 4 Pin Hub
