Mystery Misfire!
tommyhondros
62
14
e92 335xi coupe
Hello, I am having a constant misfire in cylinder 1 after recently changing to NGK 95770 at .020 now .022 and Delphi coils. In the last 2 weeks I have walnut blasted, new valve cover and gasket, new hpfp, moved injectors (all index 12) from 1&2 to 3&4 new decouplers/seals and coded. I've reset adaptations with inpa. Changed from e60 custom tune to MHD OTS pump. Consistent misfire cylinder 1 and lean. O2s/LPFP sensor/Wiring is all I can think of. I did a compression test and compression was good. Someone please help I will attach some logs. Thanks!
http://datazap.me/u/tomhondros/no-misfire
http://datazap.me/u/tomhondros/misfired
http://datazap.me/u/tomhondros/didnt-misfire-was-pulsing
