WTB Motor mounts
Bmwfixerguy1
875
292
07 335i MT
Need motor mounts
Anything other than stock, 034 or solid
Lemme know what you working wit!
Bmwfixerguy1
875
292
07 335i MT
Thank for the reply, I have broken countless 034 they are only slightly less junk then stock. Couldnt use stock where I'm at power wise
Blaster3500
296
247
SC
I have a friend selling a set of used ADE solid mounts. If interested you can call/text him at 646-593-5812. Hope this helps.
1,923
662
Why not fill stock or if you have 034 weld a plate like someone else did. Think was convert ? Not sure but easy to find when my 034 flake that's what I'm gonna do. Weird part is when anyone says you should be ok chances of that breaking are pretty low , it breaks on my car. Then when I upgrade any tiny deviation or shortcut backfires so I dont. But then dumb shit happens like rebuild tranny even though no slipping and was holding with good pressures etc and boom clunk into first piece if rubber gasket blocks solenoid lmao should left that one alone . Anyway lount is my motor came out 6 times and my 034s have about 6 or 7k fbo inlets outlets miles on them and they were fine go figure. Now that I said that we will see what happens.
034 is junk. Get revshift and be happy. ECS just approved my return of 034 motor mounts 1.5 years later. They know the product has issues. Granted I took them off well over a year ago.
