Fellow N54 friends, I would like input and ideas. I'm new to the form and this problem is driving me insane. My car is currently experiencing a mixture control problem on bank 1 ONLY. Under boost stft will go to -32%, even under light acceleration. It is also Throwing corresponding misfire codes for bank one.
Here is what is done to my car:
MSD80, 335xi
Custom Motiv Flex fuel tune from CKI@Motiv
VRSF factory side inlets
AEM LPFP pushing 75 + psi
Duel cone intake
ECS tuning charge pipe and BOV
ECS tuning Oil catch can
Pushing 22 psi under optimal conditions, E60 ish
95k miles
stock turbos
stock Down pipes
Stock inter-cooler
Stock everything else
Here is what I have done:
Changed injectors and replaced seals on injectors with proper tools
Checked injectors for leaks
New NGK spark plugs (I tried .022 and .018 gap)
New Delphi ignition coils
Replaced all Mosfets
Cleaned and inspected intake manifold
Plugged fuel tank vent port on TB
New intake and TB gaskets
Plugged intake ports in valve cover.
New valve cover gasket
Cleaned map sensor
Replaced both upstream oxygen sensors.
Compression check, 180 psi +- 5psi on all cylinders
When the problem started, It was like a switch was flipped and then it ran like crap since.
I have attached data logs using mhd covering this problem for those willing to review them. I've communicated with Chris CKI@Motiv about this, but hes a busy guy.
I'm running out of ideas. I'm going to pull the turbo inlet on bank one and check the turbine, but I have no smoke or water coming out the exhaust.
The car idles fine, but almost makes a sound like it has a huge vacuum leak under any driving condition. Thoughtful input is appreciated
MSD80, 335xi
Duel cone intake
95k miles
stock turbos
stock Down pipes
Stock inter-cooler
Cleaned map sensor
2018-05-25 16_21_28 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv80.8 KB · Views: 250
2018-05-25 16_17_26 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv92.8 KB · Views: 203
2018-05-25 16_07_53 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv58.1 KB · Views: 202
2018-05-25 16_04_51 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv15.2 KB · Views: 198
2018-05-08 14_13_16 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv29.1 KB · Views: 189
2018-05-01 17_39_50 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv33.5 KB · Views: 206
2018-04-29 16_19_56 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv15.1 KB · Views: 198
2018-04-29 16_19_22 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv5 KB · Views: 187
2018-04-29 16_19_32 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv8.9 KB · Views: 174
2018-04-29 16_18_50 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv9.6 KB · Views: 209
2018-04-29 16_17_23 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv7.2 KB · Views: 194
2018-04-29 16_04_16 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv154.5 KB · Views: 224
2018-04-29 15_44_01 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv16.1 KB · Views: 212
2018-04-27 19_55_16 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv10.6 KB · Views: 179
2018-04-27 19_49_33 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv69.7 KB · Views: 186
2018-04-22 12_56_36 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv17.3 KB · Views: 191
2018-04-22 12_51_35 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv76.1 KB · Views: 167
2018-04-22 12_52_59 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv129 KB · Views: 209
2018-04-22 12_47_10 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv233.2 KB · Views: 221
2018-04-21 07_01_17 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv38.3 KB · Views: 220
2018-04-21 06_57_51 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv230.8 KB · Views: 211
2018-04-21 06_54_39 I8A0S V2.00_Motiv_FlexFuel_Ross_OEM_FBO.bin.csv118.9 KB · Views: 203
