MHD app enhancements thread
JimboFresh206
289
152
335/635/535/533/633
Anyone else having issues logging into 2.0? I get different errors if I try a normal login in vs. Google account. Neither work :/
typedRew
412
221
2009 335i xDrive
2.03 is working good aside from having crashing issues on my nexus tablet.
I’ve tried developer options on and off, I still get crashes with 2.03. faurly frequently. I’d say an hour drive it happened 3 times. One time after a log, the others it was just running gauges.
othrr than that, working good
Jake@MHD
Nov 7, 2016
1,616
2,083
Philly
How old is the nexus? Could be memory issue
2,271
817
what? Here in germany things are different. They don´t sit in your car ... omfg. They make noise tests if they suspect something wrong.
Same here in oz. if they suspect your car is defective they have roadside testing stations for roadworthiness, noise, emissions. It can be much worse than our yearly roadworthy inspection which is done by a local mechanic.
687
If they think that your car is modded illegal than they have the right to take you your car away and bring it to an official expert who checks it then. And of course.. you have to pay it all then. You don´t want this to happen.
  • Wow
Reactions: F87Source
They cant take your car in oz but they can make you get it tested and they give you a certain time to do in like 14 days
typedRew
412
221
2009 335i xDrive
its a 2013 model nexus
it has 12gb of open memory unless you mean ram in which case I have no clue. But it’s not running anything else and doesn’t have any other apps on it but xhp
Jake@MHD
Nov 7, 2016
1,616
2,083
Philly
I looked at some crash logs, when it crashed when you were running the gauges were you trying to change the param on one? Also, if it's not connected to the internet regularly, please connect to the internet and then launch the app a few times (so we can get your specific crash data)
Reactions: typedRew
typedRew
412
221
2009 335i xDrive
I charge it inside the house connected to WiFi after every drive normally. It’s there now.
no changing anything when it crashed. Just glanced over and it wasn’t running or would not respond. Rebooted once and still did the same thing. Very well could be on my end, just wanted to make you aware
F87Source
332
152
Canada
2017 Bmw M2
My app crashes when I'm just driving, no gauge manipulations are being done. If it crashes again I'll pull over and connect it to the internet.
I'm starting to suspect it's the obd2 adapter shaking loose because the F series adapter does have a bit of weight to it and the connection to the port isn't that tight.
Reactions: typedRew
