MHD 2 step/NLS realistic eta?
gorspeed
76
27
Columbus
this thread.
digitalashley
78
135i n54, E87 N54
hi, is there any update for mhd users with regards to the anti lag ? or with being a part of betas for mhd? i'm a beta user via play store but haven't noticed any differences. curious
1,286
781
If you don't need 2 step, you can already nls with mhd with the pi safety.
From Jake:
"yes, you can NLS now if you so wish. Shift bog delete + PI Safety will cut fuel and spark when hitting the RPM limiter, so as long as you set your RPM limit in gear to somewhere around where you want to NLS, it will work fine. It won't hold as much boost as full NLS logic with timing retard, etc, but it does a solid amount as people have been seeing 20+ psi between shifts."
1,286
781
I meant to try it at the track last weekend but forgot :(. Only got 2 passes in the whole day. Was really hoping it would have been sparse because of covid-19, but everyone must have had that idea since it was packed! and hot.
Blaster3500
296
247
SC
Let me know how it turns out! Are you running PI? That is how my local 1/4 track is. Get 2-3 runs and sit in the staging lanes for 4 hours.
1,286
781
No PI here, but he said based on how it cuts fuel and spark it would work. If you are running PI, you may want to make sure there won't be any other impact. What track do you normally go to? I was at Carolina Dragway. The Car Meet shootout at Darlington got postponed until July 25th . You should try and make that - it's not just a race event, they do test n tune as well. They also have roll racing (1/4 only tho) which is fun regardless of how silly it is.
