JPWorkz Bottom Mount Kit
If I’m not mistaken he hardly hit over 700whp. It all depends on the fueling support and turbo. JP kit has hit over 700whp with the top mount running a 6266 GEN 1 turbo so anything is possible, but of course others will doubt this.
A jp works kit holds the platform record for 60-130 if that means anything to anyone
You really haven't looked too hard have you? Pretty sure multiple dynos on their page over 800, then you have scorp making some serious power..
I honestly haven't looked very hard just seen a few members here post there dyno slips I remember one guy mad like 750 wheel on a sxe364. But then I heard a guy popping the motor on them with a 6875 at like 25 psi. Seems weird to me when I've done 30 psi on a 6875 lots of aggressive dig hits and 60-130 hits . Those short runner build up to much backpressure ? I kinda got scared out of a speech tech when I heard about so many people popping there motors with that kit. Its a solid kit but for some reason I see more single turbo guys pop motors on that kit that any other kit id say.
Dumaurier7
693
316
You cannot directly link popped motors to any particular kit, its just not that simple! performance and longevity is largely dictated by the motors health as well as the function of all the parts in the kit. Unless ridiculously small internal diameters are used, back pressure would not be an issue at such low power levels, remember 10lbs/hr. of air is required to make 100 HP so flowing 70 or 80lbs/hr. to make 7 or 800 is quit doable for the average exhaust manifold design. The largest restriction in any turbocharged system IS always the size of the turbine wheel, if you look at any provided turbine flow map you will see numbers in the 30s and maybe 40s depending on a/r, this is why it is critical to match the turbo properly to obtain good (spool) performance AND overall reliability, personally I go for the largest recommended turbine wheel with the smallest a/r housing.
nyt
335
2010 335xi
The top mount, which isn't as poorly designed as this.
Whats the i.d. on the runners on the speedtech kit?
I believe they match the exhaust port size, which is what you want. I didn't measure exactly, but it looked proper when I installed. This keeps the exhaust gas velocity up. If your runner expands, you lose velocity.
Any popped motors has nothing to do with the design of the speedtech manifold. It's one of the few on the platform that have been properly engineered.
Reactions: RuskiRacer
N54TT
136
41
2013 335is
spoke to a few tuners and sent detailed pics of the manifold and it’s perfectly fine. The log style manifold becomes a issue when you’re pushing 800+ WHP and that’s never the case for any average Joe on a stock block. Case closed suit case closed. I’ll post up dyno results after June since that’s when I’ll be installing the kit. Maybe I should of purchase the speed tech kit so I can actually show dyno numbers and back it up.
Hahhaha nothing better than some back to back comparisons. Definitely get back to us with the numbers!
Reactions: N54TT
Let's keep this thread in the realm of N54 specific talk otherwise I will have to move this out into the octagon.
