Idle surging
NoGuru
1,213
597
Just North of Detroit
BMW 335is
Where to begin. I was having issue with my FF system and Motive sent me a new wiring harness. I replaced the harness and went to start the car. Now I have this idle surging that is really bad. After much flashing and testing I now have the FF module removed and the car is flashed to stock, and still surging.
I have reset Throttle, Octane, and idle adaptations, turned car off, waited 30 seconds, turned on key, waited 30 seconds and started the car and the surging continues.
I have removed the throttle body and inspected it and the wire harness and it seemed fine.
Codes:
- DME active codes -
2CFA - DME: Throttle-valve potentiometer 2.
2CFB - DME: Throttle-valve adaptation value.
2D09 - DME: THROTTLE.
2D1D - DME: Accelerator-pedal module, pedal-position sensor 1, voltage supply.
short video
  • Sad
