I8A0S Burble tune / not very aggressive?
xMoses88
Hello, so ive made my way through the forum and a lot of threads. Especially the discussion about MHD definitions in TunerPro for I8A0S SW.
Ive made changes to my burble map and the trq reduction was set to 0.
Also ive made it switchable in sport mode, but the burble are literally only small burbles (Just like the MHD setting set to soft).
I want to play around with the tunerpro settings to custom tune cars. Instead of buying MHD license.
Is there a way to set the burble more like small shots (Just like mperformance exhaust and burble setting set to hard on MHD)?
Ive tried MAIN ignition table but that made the car very jerky.
Tried adding some fuel but that didnt work either, so i guess i have to use some kind of throttle / decel maps.
Someone that could give me a hint ?
My ignition retard on decel is around -9° (Logging).
Any tips?(the -40 ignition was just a test if the car reacts to the ignition change)
2aesthetic4me
12
Öhringen Germany
BMW E92 335i 2006
Personally i tinkered with the Burble Ignition Timing Table. I found a Thread where the burble ignition was discussed and just copied one of those. This combined with longer durations made the Pops pretty loud and "shotlike". My laymen opinion is that this would be the right table to manipulate
xargentum
BMW E93 335i
Hello, maybe you remember which table defines duration between pops?
Reactions: 2aesthetic4me
xMoses88
Do you have a screenshot of the tables you used?
2aesthetic4me
12
Öhringen Germany
BMW E92 335i 2006
These are all the tables I modified in order to make burble work. On map 2 I slightly modified the burble ignition and I believe it made the burbles more intensive. I really don't know what I'm doing here so don't take my advice for granted, but I believe that the burble ignition timing table is the right one to modify for more gunshot like burbles
xMoses88
View attachment 108060View attachment 108061View attachment 108062
Thanks, do you have a video of the burble ?
Maybe upload it on we.transfer. Would be nice to hear the difference
You really did 5 seconds on duration? It never stops 😁
Neophyte
155
66
08 335i
Leave the main table as normal. Please try Carabusers xdf at this post. Try -8 as suggested enjoy.
xMoses88
I’ve used his xdf, modified duration on 2 sec. And my ignition table looks like below.
The only thing it does is making some light burble. Didn’t touch main ignition
Tried adding fuel but that didn’t change anything
2aesthetic4me
12
Öhringen Germany
BMW E92 335i 2006
Uploaded three Videos on YouTube. I don't know if you can hear the pops but it's louder in person. 5 seconds is really long and i wanted to change that but since I only use this map when driving curvy roads and my main map has zero bangs I just left it that way 😅
xMoses88
That’s not as loud as my 335i was before with MHD settings. And that’s what I’ve wanted to archive:
That was burble setting on hard.
But the ignition table only makes burble and no shots at all.
2aesthetic4me
12
Öhringen Germany
BMW E92 335i 2006
It makes a few louder shots and then returns to normal burble. My phone does not pick it up that well
