Hi Guys,(gals), Newby c/w e93n54.
65plus
So much to do, so little time & even less $$$$. The car came with cone filters and huge catless downpipes and a stage 1 something or other. Looking to do the crank hub fix/swap from Vargas.Also the bigger inner cooler and larger intake pipes, swapping the turbos chra to the TD04.and go to the next stage of tune.Needs to be dependable and be able to stop Which is how I came across the article on this website doing the F-30 brake conversion.outstanding work by the author. I won't be posting much if anything But I'll probably ask questions as BMWs like this are new to me. Good to be here, so far.
65plus
I Know how heavy the roof ¨package¨ is, 200lbs. Third thing to fail since possession in june 21. After cooling fan(chinese) and front control arm bushings(wore out). My brother and I had to pick it up out of the trunk . But I keep looking for a couple hundred feet of naked road to put down 2 long black marks. Addictive.
