Help with N54 Cyl-1 Misfire Please!
KPDcompany
34
Cincinnati, Ohio
2008 335i E90
I have posted on n54tech and have gotten great help, as well as e90post, but still havent fixed it, so I wanted to get some other input from some others. Car is stock turbos, FBO on E60. Cylinder-1 misfire is consistently at high rpm near redline and would not happen on jb4 map 1, but does on map 7. I have swapped coil packs between cylinders 1 & 2, swapped spark plugs between 1 & 2, put new NGK plugs in gapped at 0.019(95770, new 5992's) and then just yesterday put a new index 12 injector in cylinder 1, coded correctly and still the same misfire. Which really sucks because that means the injector I pulled out was fine, it was dirty, but really not nearly as bad as you would normally see. All coil pack wiring grounds are tight and have been loosened and re-seated. I am not sure what could possibly be going on. It would not let me attach a csv log from this morning when it misfired, so I put a link to the datazap log. As you can see in the log, all cylinder ignition timing look to be identical but cylinder 1 still differs from the other 5. I am at a loss here and hopefully someone here can give some insight. I have new OE Bosch plugs that I will but in this evening to see if that fixes anything at all.
https://datazap.me/u/kpdcompany/another-mis?log=0&data=1-4-11-25-26-27-28-29
Rcboosted2007
902
90
Parts unknown
07 335i
KPDcompany
34
Cincinnati, Ohio
2008 335i E90
Thank you for looking into this, I really appreciate it. It has a 450 walbro and about E60 fuel in it. It is weird. From what I thought it was cutting injector in cylinder 1 for some reason? I thought it was "sensing" a misfire situation and cutting that cylinders fuel, which in turn is why the afrs went up, is what i thought. It doesn't make any sense to me. The only thing I was thinking it could be is that cylinder 1 injector seal is loose, maybe from previous someone did it wrong? I was going to replace the oring tonight and see if it fit tighter as it does feel looser than others, but there is no combustion blow by past the oring, but maybe the higher boost is allowing the injector angle to be moved therefore making it sense a misfire? Maybe this isn't the case? Have any other thoughts or does that sound plausible?
Rcboosted2007
902
90
Parts unknown
07 335i
I feel it more of a control issue then a hardware issue, only becausw you dont have such issues with a more conservative log, etc. I ended up going PI. To eliminate the e85 mixing mess, and now run full e85
KPDcompany
34
Cincinnati, Ohio
2008 335i E90
Ok got ya. It seems like fuel pressures are ok, but from what it looks to me the fph only drops when it misfires. Also fyi i havent had any other codes, but not sure if a sensor could still be bad? The weirdest thing is cyl1 injector is brand new, as well as all plugs. but still misfiring or sensing a misfire there. I can check for air leaks, but I feel like if that were the case I probably wouldn't be hitting boost target would I? The only reason I thought cylinder 1 injector seal/bore is cause I could wiggle that injector, it is new so maybe its a faulty seal that isn't expanding like it should, and I just figured the reason it arose on higher boost was because of that extra pressure increase causing the injector to be able to wiggle or move thus causing it to think its going to misfire due to that variance? I thought about turning off misfire detection on the flash to see if it still actually "misfires" or if its just sensing that its going to or thinks it is. What kind of control issue would you think it would be?
KPDcompany
34
Cincinnati, Ohio
2008 335i E90
No regrets here! The supercharged new 5.0 was covered by the huge smoke screen the car let out AND I KEPT PULLING AWAY
HAHA, I just built a house, and about to have a patio done, so I would have regrets, hah.
BUT I did turn it off, ran great, no misfires, but boost was a little lower than it was when misfiring. I had my tuner do it for me, and he is going to adjust it some to get boost up to verify. But it ran fantastic and he said everything was Perfectly healthy. So its looking like something is causing a false sense of misfire. any ideas?
Rcboosted2007
902
90
Parts unknown
07 335i
Leaning more toward a degrading knock sensor.maybe your tuner can come under with a creative way to prove that prior to replacement. Save some money for some nice cafe lights for your patio lol.
KPDcompany
34
Cincinnati, Ohio
2008 335i E90
Haha. Really think its a knock sensor without a code? What kind of creative way would you suggest? Weird how its only one cylinder though? I figured it was something else maybe.
If you have a specific misfire regardless of the tune fixing it or not... and you changed coils and injectors it means that the specific valve needs physically inspected and or cleaned. There is nothing else that can be the issue. High power tunes increase misfire potential but the fact that it is only one specific cylinder shows a physical issue.
When was last walnut blast? A yr ago? If so... do it again. I do yearly.
