[GroupBuy] MFactory DCT Flywheel
Which Flywheel do you need?
  • Changed my mind
    Votes: 0 0.0%
  • Total voters
    49
dyezak
1,767
1,518
Plano TX
335is
I’m trying to follow the logic here. Are you supposing that the crankshaft is different between 6 bolt n54’s depending on if they are 6mt, 6at, or DCT? Because if the crankshaft is the same (and it is) then the pcd is the same between the flywheels.
MFactory
245
140
When we make the flywheels, we make them in batches. IF for some reason it turns out not to fit, will you guarantee to buy all 50 6-bolt flywheels that don't fit from us?
If so, no problem. We can proceed without confirmation
Reactions: DirtKurt
Thatfastguy
F80 m3
Hi all, I have a 17 F80 m3 with an ssp spec x clutch (dct). I was wondering if this new flywheel would work for me too. If so, I’m in! I’m guessing 6 bolt design is right for my setup. Thanks!
4,342
Totally put this off but the Flywheel was shipped yesterday and will be in their hands on Monday.
Reactions: houtan
MFactory
245
140
8-bolts are fine, but as we are making the whole batch together, we need to wait for the 6-bolt confirmation first
brandon818
10
335is
I have a 2012 335is,
(Production date Feb 2009 and later)
2009 and later, not a good choice in words, later as in prior to 09 or later as in after 09?
Which would my car need?
4,342
You're six bolt.
It means february 2009 build dates and later, are six bolt.
Reactions: brandon818
335is02
113
45
2012 BMW 335is
I have a 2012 335is also so six bolt for me also count me in.
MFactory
245
140
Hey guys,
sorry for the delay with this. We've finally managed to confirm the fitments, and everything is good to go, so we can now start to accept deposits.
price is $499.95 inc free shipping within US/Canada/Europe (other countries, please PM for shipping cost). We will require a 50% deposit ($250) to secure your place in the group buy.
current ETA is around 6 weeks. As soon as they are ready, I will ship out a sample to doublespaces to test the fitment to make sure everything is ok. We can then proceed to ship out the rest of the batch.
if you are interested in joining the group buy, please PM me :)
dyezak
1,767
1,518
Plano TX
335is
You can actually make power without false knock the dual mass system induced into the piezo sensors used for knock detection.
Reactions: NoGuru
dzid_
54
35
US
135i 2011 DCT
I am trying to understand the pros vs cons with this "upgrade".
Just eliminating possible vibration at high RPM's?
If someone provides moment of inertia [kgm2] for the lighter flywheel (which should be easy to obtain from any CAD) I could roughly calculate torque gain per gear. The torque increase depends on overall vehicle acceleration, so expect biggest gains when going downhill.
Even without provided inertias, fact is that this mod will make the biggest difference for lower gears (when engine revs up quite quickly), where we don't necessarily need that much more torque due to traction.
Also lower engine inertia should allow for faster shifting. But here is a catch. The transmission control SW has the original inertia values incorporated, so first off all it will be targeting original gear ratio change rates and controlling in close loop clutch torque to achieve old rates. And second since the close loop will be reducing clutch torque to achieve calibrated rates, I would expect clutches adaptation to be affected by that to (if they perform clutch adaptation during shifts, which is likely). So the clutches will adapt apply lower torques. Which is opposite to what we want, because in gear, the torque that will be going to the transmission will be generally higher with lighter flywheel, so in lower gears (for which torque increase will be noticeable) we could become to see clutch slip after adaptations. However, depending on how the software is done it is very likely that in gear, transmission clutch valve becomes fully opened, and clutch clamping force at this point is determined purely by line pressure. So as long as the line pressure margin is enough, it should be ok.
To summarise, I think trans should be fine. Initially I would expect slightly (because close loop doing its job anyway) faster shifts and after adaptations do their job, back to old shift times. My guess is also that line pressure defines clutch torque when in gear, so it should be fine as well (that could be verified by checking solenoid currents, maybe in INPA or sth).
BTW, with lower inertia, the launch control RPM level finally could be adequate for this car.
houtan
650
331
135i N55 DCT; PS2
i am looking forward to hearing feedback once these are installed. My main concern with this version versus the OEM version is this is single mass. If drivability is stock like, this would definitely be the option I would go with.
ganque
60
15
BMW 135i N55 DCT pure stage 2
My car is a 2013 135i N55 with DCT. Which flywheel do I need? I'm definitely interested!
