F2X First N55 Build
Dumaurier7
644
281
Hello all, after an unfortunate accident my car and engine block were damaged, I am presently in the process of rebuilding both. I have since secured a brand-new block which is now at CSS waiting on the CORRECT pistons to be delivered to them. Together with the CSS work, the build will feature CP pistons and Rods, ARP head studs, upgraded cams and springs (not acquired yet), S55 oil pan and oil pumps. S55 dual HPFPs (which I may upgrade now), S63 injectors, EOS intake manifold and a set of Big Boost upgraded S55 twins! it will essentially be a cross between the N and S55 engines. I have not purchased any bearing sets yet because I cannot decide which to get as I do not have any experience with upgraded bearings, so I need your input, can anyone help?
walker16
7
Unfortunately I dont have any advice besides King bearings is what everyone has told me. But were kinda going through the same thing. I was planning on a N55 build but just happened to come up on a S55 long block... Im debating on which motor to use but really hoping the S55 is gonna be possible within reason. Ill follow this for sure and share any advice I can...
The thread for my project...
6inarow
20
14
Seattle, wa
435i
Also in the process of a forged build. I’m using ACL coated and extra oil clearance main and rod bearings, ARP2000 head studs. My builder is gonna order the head gasket. MLS from cometic.
6inarow
20
14
Seattle, wa
435i
Don’t know much about their brand. I only have orderd parts from their website. Ask your builder or call around some performance shops and ask what they run in their performance builds. My machinist recommended ACL, so that what I’m running.
Reactions: Dumaurier7
6inarow
20
14
Seattle, wa
435i
What cams are you looking at? Really only saw schrick, and CAT. Schrick gives more lift, CAT gives more duration, but the lift is close to the schricks.
Dumaurier7
644
281
Their specifications look close enough so I am considering the CATs just because of the lower price point.
Reactions: 6inarow
Ali_X
7
Hi,
For my N55 EWG We changed mine for oem with a wbc coating I think it's the most suitable to respect the clearence of the crankshaft.
Dumaurier7
644
281
I think I’ll be going this way as well, I’m liking the 5150 Autosport bearings for this.
