well this log is of a turned off car.
I wanted you to start the ignition, start the log, then turn the engine on and leave it running for 30-40 seconds untill it goes out of open loop. preferrably a cold start.
And if you don't mind, after you get this one. turn the engine off,and then repeat the whole thing in another log.
Reason for that is that i am still chasing weird startup issues and long crank sometimes. I am zeroing in on the problem, i think. looks like it's related to rail pressure being too high. so i want to see how a working car is performing.
Is this what you are looking for? I started the car cold and recorded it. If it is I will do a start hot.
