Eric's E92 build
Erichale77
827
447
Clearwater, FL
07 E92 coupe
Powder coating is very reasonable. While I was having my wastegate springs changed I noticed my front sway bar out. (It's Eibach red) So I had it Powder coated black ( because Everything on the car is black except for rear sway bar) and it was under a hundred bucks. If I ever drop my rear diff I'll powder coat the other sway bar too.
boostE92d
150
86
Houston TX
12 335is
What did you decide on for flares? I don't really like the idea of rivets but it would be the lightest way to go.
Erichale77
827
447
Clearwater, FL
07 E92 coupe
NO rivets for me. I cant stand the way the LB walk widebody looks. I'm going to have my quarters widened with extra metal and also add more to the bumper material. It will look like it came from the factory like that when it's done. Plan on adding an extra 3 inches or so total. Just enough to fit a 315 on.
boostE92d
150
86
Houston TX
12 335is
I they can do it without a bunch of filler. Bodywork always involves at least some of it. It will look good for sure.
Erichale77
827
447
Clearwater, FL
07 E92 coupe
No misfires. Car ran pretty smooth on just one HPFP and no PI. Made just over 700whp. Going to activate second HPFP and then slowly ramp in PI next. At least base map is done and will only need small revisions from here on out. Spools great for a 6870.
4,345
Wow, so essentially a single shotgun made 700whp, what fuel?
Erichale77
827
447
Clearwater, FL
07 E92 coupe
My tuner has all the logs as he was creating a base map first. I'm sure they are nothing special to look at yet but I will post some when the tune is closer to being finished. As for my setup it's not a kit, it's custom twin scroll bottom mount from FabFactory.
Red90
46
20
E90 335i
OK cool,is this something that fab factory have available or was it just a custom build?
