Enable SSD TRIM
superwofy
134
204
Won't go into too much detail on what T.R.I.M. is but the short of it is that when using an SSD you want this enabled.
As it happens fs-qnx6.so actually supports this out of the box but it is not enabled since EVO uses an HDD by design.
devb-ahci-hbomap5 is the driver that controls the CD drive and the HDD ports.
Code:
CD arguments: ahci ioport=0x5E406000,irq=516,xlat=0x30000000,bs=speed_limit=0,bs=cmd_abort=none blk cache=1m,vnode=256,delwri=2,marking=none,noatime,memory=/ram/dma udf verify=none cam resmgr,verbose=1 cdrom timeout=30:30:30:30,retries=3 mem name=/ram/dma
HDD arguments: ahci ioport=0x4a140000,irq=86,bs=speed_limit=0 blk cache=32M,vnode=256,delwri=2,marking=none,noatime,verbose=bf cam cache,async,timeout=35:35:35:35,verbose=1,retries=3
To enable TRIM for the HDD port simply add an option to the qnx6 driver in the arguments list: qnx6 trim=enable.
I.e. the new HDD arguments would be:
Code:
ahci ioport=0x4a140000,irq=86,bs=speed_limit=0 blk cache=32M,vnode=256,delwri=2,marking=none,noatime,verbose=bf cam cache,async,timeout=35:35:35:35,verbose=1,retries=3 qnx6 trim=enable
Bootlog before:
Code:
hu-omap:/dev/shmem> sloginfo | grep trim
Jan 01 00:00:00    5     3   1000 fs-qnx6: /fs/sda0 trim not enabled
Jan 01 00:00:00    5     3   1000 fs-qnx6: /fs/sda1 trim not enabled
Jan 01 00:00:00    5     3   1000 fs-qnx6: /fs/sda31 trim not enabled
Jan 01 00:00:00    5     3   1000 fs-qnx6: /fs/sda32 trim not enabled
Jan 01 00:00:01    5     3   1000 fs-qnx6: /mnt/data trim not enabled
Jan 01 00:00:01    5     3   1000 fs-qnx6: /mnt/share trim not enabled
Jan 01 00:00:01    5     3   1000 fs-qnx6: /mnt/quota/mm trim not enabled
Jan 01 00:00:01    5     3   1000 fs-qnx6: /mnt/quota/sys trim not enabled
Bootlog after:
Code:
Jan 01 00:00:01    5     3   1000 fs-qnx6: /mnt/data trim enabled
Jan 01 00:00:01    5     3   1000 fs-qnx6: /mnt/share trim enabled
Jan 01 00:00:01    5     3   1000 fs-qnx6: /mnt/quota/mm trim enabled
Jan 01 00:00:01    5     3   1000 fs-qnx6: /mnt/quota/sys trim enabled
To make this change edit /opt/sys/etc/starter.cfg
Reactions: zomboi09
