E8x/e9x eDiff coding
derekgates
740
375
NW FL
derekgates.us
2011 335is
So I've been trying to code out the e-diff along with a few other nannies using Protools. Even thought I've disabled everything, it looks like I'm still getting a lot of interference(traction control light flashing). Has anyone else had this problem after using Protools?
Long press/hold of DTC button to disable completely. Otherwise the intervention, even at "half off", will intervene. The Non-M DSC is extremely sensitive.
Reactions: AWCR1MC
nahor
54
35
2010 BMW 135i Single Turbo
You can control this to some degree in your tune with the Torque Max Intervention Mode table actually; the base map I used to build my own had these values set really low (30 across the board, I believe), and traction control would intervene even at the slightest hint of wheelspin. Raising them up helped a good amount, half off mode feels pretty good to me now. I don't think it affects stability control at all, but it definitely did traction control
