I am just thiking of my problem right now. I want to run pump fuel only on my pure stage2 cast. How do you monitor LPFP on Z4. I just bought fuel line and sensor from 335.I have the 535 lpfp in my z4 and are monitoring my pressure. When I start my car I have 72 psi pressure, but after a few seconds it drops to 68psi at idle.
At WOT the low pressure is dropping a little more to about 62 psi.
This is with 17t turbos, e30 fuel mix.
Is there a way to raise the lpfp pressure to 72 psi all the time?
I just added a old style pressure gauge with a hose into the 335 fuel line... instead of the oem sensor. Just putting the gauge at the windscreen on my wiper when I want to look at it.I am just thiking of my problem right now. I want to run pump fuel only on my pure stage2 cast. How do you monitor LPFP on Z4. I just bought fuel line and sensor from 335.
Hi. Does someone tapped in the e89 long fuel line. I want to put in check valve but read somewhere that e89 have bigger diameter fuel line. To be clear i even dont know the inside diameter and what fittings to use to convert from AN type to fuel line..
