DIY tuning
cookiesowns
26
2010 535i ZHP6 + 2017 M2 6MT
The PID WGDC tables aren't as hard to understand some of you make it out to be :)
Generally you can leave the PID along on stock turbo, and tweak the base WGDC and Feed-Forward tables, along with adder airflow to get what you need. PID only needs to be tweaked if you have different spool characteristics ( high flow, or catless ) along with a way more aggressive WGDC base/feed-forward tables.
bradsm87
162
53
You're thinking either N54 or Cobb's incorrectly labelled N55 tables.
N55 does not have WGDC Base. The WGDC starting point is a calculation based on many tables.
  • Disagree
Reactions: cookiesowns
Sbrach
224
175
N55 DCT E82
Right. “WGDC base” is replaced by a compressor characteristic map that calculates the turbine power required to turn the compressor and a model of the exhaust gas flow characteristics that requires a neural network to calculate. It is incredibly complex.
That said most of the complexity is likely irrelevant with regards to tuning because the PID “takes up the slack” and I will be transitioning to PID control for my PS2 tune due to numerous factors. But just because you can make PID work in no way means that the model is easily understood or in reality understood well by anyone other than the engineers who implemented it. Perhaps with better documentation it would be better understood but I think any more documentation surfacing that we don’t already have is unlikely.
1,634
Interesting. Which table in TunerPro is the Feed-Forward table?
cookiesowns
26
No. I'm referring to BM3's table.
Take a look at KF_WGPOS_VST (Wastegate Position - für Vorsteuerung) & Wastegate Position - Modell
I refer to WG position Modell as base. as that's the base derivative.
KF_WGPOS_VST (Wastegate Position - für Vorsteuerung) :)
all4bspinnin
178
98
135i TT
KF_AUSY_TURB - Turbine flow characteristic
KF_ATM_ATLETA - ATL efficiency
KL_ETA_TURB - Turbine efficiency
KF_FGAS_WG - Gas force on the wastegate
KLEWGFGAS - Characteristic: wastegate force vs duty cycle
I've been doing research comparing the cobb ATR guide on Ecoboost boost control. I've been reading to see if there are any similarities between the feed forward tables (Wastegate Position - für Vorsteuerung 1/2).
houtan
659
338
135i N55 DCT; PS2
Would love to know the reasons why the switch to PID control. I am guessing I should be switching for the same reasons.
all4bspinnin
178
98
135i TT
PID control allows boost to adjust for all conditions: temp, altitude, ect, etc. PID is also very helpful as the wastegate ages. It can adjust to add more dc as things get lose.
1,634
One of the issues I had with the Non-PID logic (N20 TMap Scaled with MBoost Option for 22-23psi stockers) was an overboost error when accelerating on the highway from like 50 mph to 75 mph in 6th gear (AT AWD), which would throw me into limp mode. Needed to clear errors twice in MHD to clear limp mode. As soon as I went back to my PID map, everything else being the same, I’d never go into limp mode. So presumably the PID was doing its thing.
Sbrach
224
175
N55 DCT E82
Those tables still require the model of the exhaust gas flow over the turbine is accurate and with catless downpipes, exhaust changes, aftermarket turbos, etc this is not the case.
With PID control we should be able to reduce the boost spikes we see post shift, going WOT and downshifting, high gear low rpm WOT, etc. These scenarios are hard to tune around when just using commanded WG.
houtan
659
338
135i N55 DCT; PS2
Looking forward to hearing how it goes. My current commanded wgdc tune is really good in terms of boost control. But I will still switch if there are advantages.
Any progress on understanding misfires because of the stock dct flywheel?
Jake@MHD
Nov 7, 2016
1,615
2,083
Philly
PID isn't active with commanded WGDC on N55 / F-series? Yikes. I might need to change that logic a bit for you guys.
LamboLover
238
242
Everything
If I recall, PD is in the compressor power block that is bypassed by commanded wastegate. I is still used. Alterations could be good and I would like a simpler to tune method that automatically learns the wastegate.
  • Love
Reactions: Jake@MHD
Sbrach
224
175
N55 DCT E82
Yeah from what I can tell this is correct. Replacing the compressor power / turbine exhaust mass flow model with a WG base table that doesn't get rid of the P and D terms after would be pretty nice.
Desensitizing knock in the narrow rev range we see the harmonic and only for cyl 5 and 6 seems to have helped. There are more knock tables I can likely define but I don't really think this is the path anyone should take since M-Fsctory is going to be producing a single mass replacement flywheel for a reasonable price.
LamboLover
238
242
Everything
How would you want it to work? Are you trying to separate torque and load from boost and wastegate?
all4bspinnin
178
98
135i TT
I'd like it to work exactly how it works on the ije0s/i8a0s ecus. The X axis is your boost setpoint, the y axis is rpm. The value in the table is wgdc. In the table a value of 0 would indicate to run spring pressure. Anything above zero means wgdc is applied in order to hit higher boost levels above spring pressure. PID would then be applied.
Sbrach
224
175
N55 DCT E82
That’s how commanded WG works now except the CW to enable that mode also disables much of the PID.
Jake@MHD
Nov 7, 2016
1,615
2,083
Philly
RPM x Setpoint isn't the most ideal in MSD8x either, as it skips over the WGDC spool table and a few others. It also does not exist anymore in IKM0S or INA0S code. For these reasons I started building a more customized approach.
all4bspinnin
178
98
135i TT
Correct, the axis are flipped and we'd just need to apply PID afterwards.
Lately I haven't been running spool mode past 3k. I was running spool out to 3500ish on larger turbo cars and blending it in. I've found recently that I can get a more smooth boost curve killing spool mode at 3k. I guess its personal preference really. Spool mode isn't really as much of a concern for me I guess.
My main concern at this point is defining all of the necessary tables in the XDF and making sure we have the correct conversion information. The XDF's I have are filled with a lot of tables still in german with little documented explanation. @Sbrach , id like to get with you about defining a few more things when you have a chance.
@jyamona Mind sharing the details on the customized approach? Or are you using the stock tables with axis edits?
